B16A is leaking oil in the distributor area
For a while now my b16A has been leaking oil under the distributor and i think its coming out from the sensors
. how do i stop it?
. how do i stop it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">Its probably your distributor o-ring. number 6
he is correct and nice pic to show the detail.
It is probably the distributor O-ring but to make sure, clean up the area with brake cleaner or something and then leave it for a day so you can see clearly. The cam end cap is also known for leaking oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black4thgenEF »</TD></TR><TR><TD CLASS="quote">It is probably the distributor O-ring but to make sure, clean up the area with brake cleaner or something and then leave it for a day so you can see clearly. The cam end cap is also known for leaking oil.</TD></TR></TABLE>
The cam end cap is not under the distributor
A distributor o-ring is like 5 bucks...
the oil leak is under the exhaust cam cap and it goes all the way down and it seems like oil is coming out the sensors...
the oil leak is under the exhaust end cam cap do i need a new seal? and it seems like the oil is coming out the sensors too...ill put a picture up later.
A distributor o-ring is like 5 bucks...</TD></TR></TABLE>
I should hope that most people know that but sometimes it is hard to tell where the oil is coming from if your engine is greasy and that whole side is covered in oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_dxB16 »</TD></TR><TR><TD CLASS="quote">the oil leak is under the exhaust end cam cap do i need a new seal? and it seems like the oil is coming out the sensors too...ill put a picture up later.</TD></TR></TABLE>
What's that? It wasn't the distributor o-ring?? It looks like my first post was valid after all...
Anyway, you can buy a new end cap for cheap at the dealership. It isn't hard to replace, you just have to pull the valve cover etc. to get at it.
Cool Cool Island Breezes. BOY-EE
You cant use brake cleaner around rubber. If you do, even if some seal wasn't leaking before, it will leak after it's been exposed to brake cleaner. Read the can.
florida
Feb 3, 2007 03:46 PM
efking
Sep 28, 2006 12:44 PM
