Timing belt and cam gears not sure.
Old Mar 4, 2008 | 01:14 AM
adam081904's Avatar
Default Timing belt and cam gears not sure.
OK i got my motor back from the machine shop. They did not put the cam gears back on, or the crank gear. I been reading Not sure how to put the cam gears back on the right way. I know i sent the crank at TDC for the number 1 cylinder. Not sure after that. But i think i put the cam gears on, have the gears with the "up" mark go up. The line on the cam gears face each other. Some one told me that is fine but just making sure. If it helps I got a b18c1 with stock cam gears. Thanks for the input
Old Mar 4, 2008 | 03:38 AM
adam081904's Avatar
Default Re: Timing belt and cam gears not sure. (adam081904)
bump
Old Mar 4, 2008 | 05:15 AM
B16B_coupe's Avatar
HRD PKR
if you dont know how to do that i would get someone that knows how.. would hate to see a freshly done motor get destroyed from that
Old Mar 4, 2008 | 03:53 PM
adam081904's Avatar
Default Re: Timing belt and cam gears not sure. (B16B_coupe)
might do that but i'm sure it is easy. Just the repair manual was kinda unclear. And i want to make sure. I been trying to find it online and i can't
Old Mar 4, 2008 | 11:09 PM
adam081904's Avatar
bump*
Old Mar 6, 2008 | 10:54 AM
adam081904's Avatar
No one ever done this before? any info would be great. * BUMP*
9honda5civic
Oct 10, 2012 03:21 AM
integlstrike1
Aug 13, 2006 07:45 AM
Dat1BVtecN
Jul 12, 2006 09:26 AM
sph33r
Feb 19, 2006 09:53 AM
Brewer
Feb 2, 2005 10:48 AM
