D16A6 rebuild
I just rebuilt my D16A6. I went with CP 11:1 comp pistions. H beam eagle rods. Stock Crank. 8 pound flywheel. block was resleeved. ACT Heavy duty 6 puck racing clutch. Ported and polished the head with 1mm over valves. ferara valves? dont know how to spell it. and stiff springs and all new **** on the head. I have a cam that is biggest for stock fuel injection. Any idea of anything else i should do and what do you think horsepower will come out to? 150? 200? 250? maybe an idea for times in the 1/4. i ran a 15.4 with it being stock? any help please
unless i see pics I call:
what springs did you use?
How did you dial in the overlap on the cam?
What cam did you go with?
what was the cam specs?
did you use a cam gear and what kind?
what retainers did you use?
what was the head or block milled to?
did you notch the girdle?
Did your eagles come with arp's?
If so what arp's short or tall?
PICS or
NOTE: IF I am mistaken then I appologize we just get alot of noobs posting useless garbage. I live close to you and would love to see your set up in person. Maybe you could check out my Y7/A6 non-vtec "mini-no-V" "mini-me" setup
PICS or
the only pics i have now is the pistons and rods. and the car town apart. im not doing the work other than tearing it apart and yes i did grind the grindle. i dont know how to post pictures or i would.
cool I understand.
You need to read alot when on here.
Read the rules and how to post pictures. This is a technical forum so make sure you keep your tech in the right places.
To post pictures just make sure they are uploaded to an online photo hosting site:
I use:
http://www.photobucket.com
Then copy the URL into the two symbols: [IMG] "URL HERE" [/IMG]
If you need help just ask. Im really interested in seeing your stuff!
I use:
looks good. So it looks like your going all motor? Get yourself a good header or your increased valve size wont matter. Get a good honda oem head gasket too! Make sure you have some good exhaust to combine with the rebuild. All of these things make the engine build worth it. Dont expect that engine to suck through and blow out through a straw.
That engine will most likely make 150whp with a good ecu and tune job. Not sure though. Would make more with a d17 crank! Also you could make more with a newer head. Thats why I went to a Y7 head over the older A6 head.
yes all motor for sure lol... i dyno'd at 100 at the wheels and a local shop guy said that i would gain about 45-50 for the bottem end and 45-50 for the head. so i was guessing 180 to 200. and yes i know to get a y7 head gasket... and i have an better header... its not the best but it helped when it was stock. i just hope after tuning it and all i can hit 13.9's
by the info u provided your setup is reall only gonna make 130-150whp depending on the tunewhich might get your goal of 13.9 imo you over built the bottom end for n/a you could have just went with stock rods and zc pistons for alot less and netted a little more compression, but since its built put a smaller cam in there and do 100 shot of nitrous or something that will make u happy.
my old setup was 89 crx with a d16z6 swap/si trans stock bottom end, port n polished head zex cam head was milled and just bolt ons i/h/e it went 14.1@96 n/a on street tires never dynoed
you said put a smaller cam in with nitrous? would i be able to run any nitrous the way it sits? and how much. i;ve been told i can run a 75 shot and be safe. just have to retard my timing is what someone told me... not really sure, im just getting into the swing of things with this car... your guys help is making it alot better. and also what kind of plug wires should i run? i have a MSD for it, i would like to use it. would that help at all? thanks!
do u know which cam you have??? with the forged internals i would be running a 100 shot, but i would start off small then increase progessivly also upgrade your fuel pump, get a set of colder spark plugs and i think the rule with nirtrous is retard the ignition timing 2 degrees for every 50 shot of hp, also stock plug wires are ok, if u are gonna run the msd wires i would suggest using there cap aswell the new ones have a cover to hold the plug wires on since the msd tend to pop off. and i dont suggest using an msd box they dont work well with hondas, i do like there blaster ss coil though.
i dont know exactly but its a RV regrind cam. and they said tis the biggest one i can have for the stock fuel injection. so i have been asking around and noone really knows for sure... is it possible to run slicks with the set up i have. with stock axles and ****... or will i need up breaking **** when i launch?
Question ... I have got the same kind of setup but not sure how to grind my girdle what should I use to grind it??
wfocrx
Nov 6, 2007 12:45 AM
PA MATT
Mar 13, 2007 12:40 PM
