Jdm D15b Idle problem after engine install??? Please Help!!! Searched already!!
Old Mar 3, 2008 | 07:17 PM
SOHC_2_DOHC's Avatar
Default Jdm D15b Idle problem after engine install??? Please Help!!! Searched already!!
I blew my last OBD-1 Jdm D15b motor that was Greddy boosted on my 95 civic hatch. I installed another one and know i have an idle problem sometimes which surges between 1500 and 2000 rpms. I checked all vacume lines and i cleaned my iacv with carb cleaner but still the same thing. I think it might be the map sensor because i checked my codes and im pulling a Code 3 but it again comes on from time to time when i really pull hard. Maybe i just need a good tune!! Please help!!!!!!!!!!!!!!
Old Mar 3, 2008 | 07:22 PM
ke98248's Avatar
Default Re: Jdm D15b Idle problem after engine install??? Please Help!!! Searched already!! (SOHC_2_DOHC)
It still shouldn't surge idle that much -- do you have a chipped ecu on a basemap of some sort?
Old Mar 3, 2008 | 08:16 PM
Default Re: Jdm D15b Idle problem after engine install??? Please Help!!! Searched already!! (ke98248)
I have an Kenji chipped ecu, i didnt have this problem on the other motor which was the same thing as the one that is on now.
Old Mar 4, 2008 | 11:16 AM
no one has any experience with this kind of problem or any suggestions??????
Old Mar 10, 2008 | 06:12 AM
EF Boy1231's Avatar
I dont know if you have one, but you should try cleaning or replacing the fast idle valve on the throttle body. My friends car's idle hopped like crazy, he got a fast idle valve from the JY and it idle so smooth.
Old Mar 10, 2008 | 06:19 AM
JDM_SOHC's Avatar
Default Re: (EF Boy1231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF Boy1231 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if you have one, but you should try cleaning or replacing the fast idle valve on the throttle body. My friends car's idle hopped like crazy, he got a fast idle valve from the JY and it idle so smooth.</TD></TR></TABLE>
correct...
or he could just take off his FITV, screw the white valve on the inside all the way down an call it a day... thats what i did to mine 3 years ago an its been fine ever since....
crxguy406
Sep 10, 2015 03:56 AM
lsvteg11
Sep 17, 2010 11:50 AM
SOHC_2_DOHC
Mar 26, 2008 03:29 PM
mikeunreal2
Mar 29, 2006 09:27 PM
diLUDEd
Aug 22, 2002 10:08 PM
