b18 swap now speed sensor not working
Old Mar 3, 2008 | 06:27 PM
tacorunner87's Avatar
Default b18 swap now speed sensor not working
i did the swap the speedo was working fine. I when to install a thermostat switch for the fan. Well now my speedo is not working. is it possible i pulled something? if so where do i start looking?
Old Mar 3, 2008 | 06:33 PM
black0hatch's Avatar
Default Re: b18 swap now speed sensor not working (tacorunner87)
check the spedo cable maybe it got pulled out of the tranny.
Old Mar 3, 2008 | 06:35 PM
EDM-itR's Avatar
Default Re: b18 swap now speed sensor not working (black0hatch)
it looks like a short circuit
Old Mar 3, 2008 | 06:45 PM
where is the cable or plug located? front or back of the transmission?
Modified by tacorunner87 at 7:57 PM 3/3/2008
Old Mar 3, 2008 | 07:27 PM
checked the sensor all the way in the transmission. then all the plugs are tight. all the fuses are good. anything else to check? dont really want to purchase a sensor to test. there around 90 bucks.
Old Mar 3, 2008 | 09:06 PM
Got it all figured out i was looking at the wrong item on the transmission. The cable just popped out. It also fixed my check engine light kinda weird. But ill have to drive it allittle more to see.Thanks for the help.
hoga113
Mar 8, 2013 04:32 PM
B16CRXVTEC
22
Oct 4, 2011 06:27 PM
Channooo
Aug 12, 2009 01:50 PM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
Quik Chris
Aug 8, 2002 09:53 AM
