gaguge cluter Q
Old Mar 3, 2008 | 06:14 PM
b18 hatch mike's Avatar
Default gaguge cluter Q
will 00 si gauges fit inside a 94 cluster
Old Mar 3, 2008 | 07:04 PM
BlueIntegraBoy's Avatar
Default Re: gaguge cluter Q (b18 hatch mike)
That's a , rampart
Old Mar 4, 2008 | 08:27 AM
RyanA's Avatar
Where there's a will there's a way. There is a write up on here somewhere showing the pinout. You'll have to do something to make it look halfway decent though. People have put Si clusters in EF's so an EG is one step easier.
Old Mar 4, 2008 | 09:43 AM
Default Re: gaguge cluter Q (RyanA)
yeah cuz i love the si cluster
Old Mar 4, 2008 | 10:39 AM
da_dude's Avatar
I seen it done before. It's alot of work that is for sure.
Old Mar 4, 2008 | 11:54 AM
Memnoch's Avatar
no you can't put just the gauges into the 94 cluster, but you can rewire your current cluster plugs into any 96-00 civic plugs and then hook up a SI cluster and mount it with the use of some rigging... do a search this topic has been covered numerous times.
Old Mar 4, 2008 | 03:08 PM
Default Re: gaguge cluter Q (Memnoch)
na dont feel like cutting up my harness and trying to mount it i will leave the stock one in thier
but when its done right looks good
Old Mar 4, 2008 | 05:47 PM
Memnoch's Avatar
You don't have to cut anything my friend, you just re-pin the plugs, fairly easy process, and as far as mounting also simple, read around its not as difficult as it seems, took me under an hour to put a LS cluster into my EK..
Old Mar 4, 2008 | 05:51 PM
i will look then thnks
crazy_ls_90
Jul 2, 2008 12:50 PM
01-0720
Jan 24, 2008 10:03 PM
RacingShoeBox
Nov 29, 2005 10:27 PM
tyflip2
Jul 15, 2003 04:07 PM
VRD^don
Oct 22, 2002 05:17 AM
