injectors hp
Old Mar 3, 2008 | 05:23 PM
feriotypeR's Avatar
Default injectors hp
how much hp can 99 civic d16y8 injectors take? what r the best injectors? high impedence or low inpedence?
Old Mar 3, 2008 | 06:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: injectors hp (feriotypeR)
not much, best is not the answer, with out knowing what ems you are running, if the ecu is stock based.
up to 750 saturated can be ran on a stock ecu ( chipped ofcourse) with out a resistor box (obd1 ofcourse)
above 750 peak and hold will necessitate a resistor box for an obd1 ecu.
Old Mar 3, 2008 | 06:31 PM
ke98248's Avatar
DSM injectors (450cc's) are a pretty good deal if you decide to deal with forced induction or have a crazy NA build.
Old Mar 4, 2008 | 01:19 AM
feriotypeR's Avatar
Default Re: injectors hp (ke98248)
well i only desire around 200whp for now, later when i get another car, i'll add internals to it. i was thinkin 440cc. what should i do to the ecu?
hybridb18
Dec 30, 2010 06:20 PM
EKHWhat
Feb 2, 2007 05:38 PM
dave24
Aug 3, 2006 07:43 PM
aaronhume
Oct 25, 2005 11:52 PM
truent
May 5, 2003 12:15 AM
