Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic EX Door Lock Problems
Old Mar 3, 2008 | 03:41 PM
MarkKetch's Avatar
Default 2001 Civic EX Door Lock Problems
I've got an 01 EX, and my passenger side door lock stopped responding to both the wireless transmitter and the internal controls, thus I can only lock/unlock it manually.
Any ideas on what could cause this? Bad actuator? A fuse?
Thanks in advance.
- Mark
Old Mar 3, 2008 | 03:56 PM
Honda Rules's Avatar
mine did that to but my drivers side, did that for about a week until i was bored and kept locking it and unlocking for about ten minutes straight then it was back to normal, weird
Old Mar 3, 2008 | 05:14 PM
hondalove323's Avatar
Default Re: (Honda Rules)
i have a 2002 civic lx
and i have to pull the handle than lock because it will not lock the drivers side door..
i guess this happens to a lot of people
Old Mar 3, 2008 | 07:23 PM
MarkKetch's Avatar
Default Re: (hondalove323)
That's standard on all Civics. If you want to lock the driver side door while it's open, you need to pull the handle then lock it.
Old Mar 3, 2008 | 08:05 PM
d5civic's Avatar
it's a common problem. Your lock actuator is out. Most of the time it happens on teh driver side of the car though. Mine has been out, along with many other members, for years now. I'm too lazy to fix it.
Old Mar 4, 2008 | 03:45 AM
MarkKetch's Avatar
Default Re: (d5civic)
That's what I figured. From what I've read, although it's a cheap part, it's a pain in the *** to fix.
Old Mar 7, 2008 | 05:25 PM
EM2K's Avatar
Default Re: 2001 Civic EX Door Lock Problems (MarkKetch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkKetch &raquo;</TD></TR><TR><TD CLASS="quote">I've got an 01 EX, and my passenger side door lock stopped responding to both the wireless transmitter and the internal controls, thus I can only lock/unlock it manually.
Thanks in advance.
- Mark</TD></TR></TABLE>
Your not the only one with this problem, my 01 coupster has the same problem I'm 99.99% positively sure that it's a bad actuator. Like what was said earlier cheap part pain in da *** to fix.
Old Mar 7, 2008 | 05:36 PM
oddmut's Avatar
Default Re: 2001 Civic EX Door Lock Problems (EM2K)
hasn't happened to me and i aint jinxing it!
Old Mar 8, 2008 | 05:01 PM
EM2K's Avatar
Default Re: 2001 Civic EX Door Lock Problems (oddmut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut &raquo;</TD></TR><TR><TD CLASS="quote">hasn't happened to me and i aint jinxing it!</TD></TR></TABLE>
Your lucky I've had this problem for years and just too lazy to do anything about it. I kinda got used to using the key to get in my drivers side door LMFAO! FTW!
Old Mar 8, 2008 | 07:51 PM
integraa972's Avatar
same here but my passenger side lol
Old Mar 8, 2008 | 08:20 PM
tunerkid7's Avatar
Default Re: (integraa972)
definately could be fuse. I just fixed one today. and sure enough
Old Mar 8, 2008 | 08:25 PM
kharned08's Avatar
its prob a bad actuator but check the fuse just incase. that was the prob with mine, i got lucky
Old Mar 8, 2008 | 08:35 PM
d5civic's Avatar
Default Re: 2001 Civic EX Door Lock Problems (kharned08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kharned08 &raquo;</TD></TR><TR><TD CLASS="quote">its prob a bad actuator but check the fuse just incase. that was the prob with mine, i got lucky </TD></TR></TABLE>
where is this fuse u guys are talking about for the actuator?
Old Mar 9, 2008 | 08:23 AM
MarkKetch's Avatar
Default Re: (tunerkid7)
Well, if it was a bad fuse wouldn't the actuator not make the "clicking" noise when it tries to engage?
Old Mar 9, 2008 | 05:40 PM
standbackimapro's Avatar
Hmm Honda locks are so wierd, the Same thing was happening to my 97.. door locks wouldnt work with the remote.. it would make the noise but it just wouldnt lock..
i kept lockin and unlockin and it worked...
mystikalcaramel
Mar 23, 2019 01:19 PM
Qvart
Mar 26, 2015 12:10 AM
PunkRudeBoy
10
Jun 7, 2011 04:03 PM
Mindless Mind
Jun 17, 2009 08:05 PM
all stock
Jan 15, 2005 12:49 AM
