i have no brakes try #2
Old Mar 3, 2008 | 10:50 AM
seeareex's Avatar
Default i have no brakes try #2
i took the front calipers off, bled the system, no brake pedal, no leaks, the check valve has the E with the arrow pointing towards the motor, still no brakes. WTF?
Old Mar 3, 2008 | 10:56 AM
Lo-Buck EF's Avatar
Default Re: i have no brakes try #2 (seeareex)
why did u take the calipers off, then bleed the brakes?
did u bleed w/ the e-brake up?
pandarex's Avatar
master cylinder or brake booster are bad. did they just stop working one day, or are you saying you took the front calipers off and now they dont work?
Old Mar 3, 2008 | 11:00 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
uhmm also is there a particular reason this brake setup made you make two threads about this? I've seen one thread cover more then enough information for you to get an answer..........
Old Mar 3, 2008 | 11:01 AM
seeareex's Avatar
i just bought the car, took the calipers off to repaint them, put them back on, bled the system, no brakes, the car wasnt running when i bought it so i dont know if they worked or not
Old Mar 3, 2008 | 11:03 AM
Lo-Buck EF's Avatar
Default Re: (ComeOnKip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">uhmm also is there a particular reason this brake setup made you make two threads about this? I've seen one thread cover more then enough information for you to get an answer..........
aah. one of those.
seeareex's Avatar
actually yes there is, because i bumped the last post, and didnt get an answer, so layoff
Old Mar 3, 2008 | 11:59 AM
alscrx's Avatar
Default Re: (seeareex)
So the pedal just sinks to the floor?
Old Mar 3, 2008 | 12:25 PM
seeareex's Avatar
yes
Old Mar 3, 2008 | 01:06 PM
CRX Toad's Avatar
Please keep this all in one thread. Thank You
https://honda-tech.com/zerothread/2240362
rexfan
36
Aug 31, 2009 11:43 AM
JDMPR
Jul 18, 2009 02:09 PM
gophat
Jan 7, 2007 05:32 PM
DriveSideWays
Aug 7, 2004 05:34 AM
Milano_EH3
Aug 17, 2003 04:01 PM
