fuel filter problem. please help.
ill be driving at 65mph then it will bog or seem as if the car was shut off even though its still running. the clutch is not slipping and when the jerking is taking place my rpm do not drop. when i push in the clutch my engine revs just fine but not under load!
i have a stock dual point EF.
im assumimng its a fule filter or injectors.
do you get a check engine light or a code on the ecu. Mine was doign something similar, but it would give me a code for a distributor problem, I forget what exactly it was though.
i just pulled my spark plugs and they were saturated in oil. im guesing thats my problem.. a bad head gasket, anyone have a quick fix?
