Why the hell is my car so loud at speed?
Old Mar 3, 2008 | 10:06 AM
FBS's Avatar
FBS
Default Why the hell is my car so loud at speed?
I've got an 88 CRX DX, automatic. Lately the car has picked up a loud hum/drone in the drivetrain... It starts at about 60 mph, but really gets loud at 70 and higher... I know it's not anything in the engine, since i can put the car in neutral and the hum doesn't change.
The weird thing is that it changes when I turn... at 70, it gets a little quieter when I turn the steering wheel more than 5 degrees right... And when I go left, it goes away almost altogether.
What the hell is it? I've made sure my wheels are bolted on tight, but I really don't know where else to look.
Old Mar 3, 2008 | 10:27 AM
s1267712's Avatar
Default Re: Why the hell is my car so loud at speed? (FBS)
could be a wheel bearing. sometimes when they are going bad, when you turn they are loaded differently and the sound will changel.
Old Mar 3, 2008 | 12:43 PM
doublethink's Avatar
Default Re: Why the hell is my car so loud at speed? (s1267712)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s1267712 &raquo;</TD></TR><TR><TD CLASS="quote">could be a wheel bearing. sometimes when they are going bad, when you turn they are loaded differently and the sound will changel.</TD></TR></TABLE>
x2
Old Mar 3, 2008 | 01:29 PM
CRX Toad's Avatar
Default Re: Why the hell is my car so loud at speed? (doublethink)
I had a rear bearing go south and I could barely hear anything from the drone. It was terrible. Turn one way it would go away turn the other it got louder.
Old Mar 11, 2008 | 02:14 PM
FBS's Avatar
FBS
Default Re: Why the hell is my car so loud at speed? (CRX Toad)
So I pulled the rear passenger bearing and replaced it, because it was a noisy when I spun the hub while the car was on jackstands... put everything back together, drove off... and it's making the exact same noise.
How do I tell which side is bad? I thought it was the front driver side, but it seemed fine...
is there anything else this could be? I don't want to drop $150 on bearings and find out they're not even the problem...
Old Mar 11, 2008 | 06:28 PM
FBS's Avatar
FBS
bump!
Old Mar 11, 2008 | 06:36 PM
SIred91's Avatar
Rainman
Either gonna be wheel bearings or an axle joint or differential
Old Mar 11, 2008 | 07:11 PM
coot_er's Avatar
Default Re: Why the hell is my car so loud at speed? (SIred91)
grab each tire at 3 and 9 o'clock and shake them. if a bearing is bad you will feel a small amount of play.
Old Mar 23, 2008 | 04:50 PM
FBS's Avatar
FBS
Default Re: Why the hell is my car so loud at speed? (coot_er)
just got back from vacation and i've been fiddling with it, and I'm still not convinced it's a bearing... there's no noticeable play in when i wiggle the wheel.
BUT i took a good look at the tire on the driver's front... What the hell is this dent? This can't be normal...
Old Mar 23, 2008 | 04:56 PM
White91EF's Avatar
maybe the tire beads popped out? i dont think that would make the sound your talking about though... but i could be wrong
Old Mar 23, 2008 | 05:09 PM
turboZChatch's Avatar
Default Re: Why the hell is my car so loud at speed? (White91EF)
looks like you hit a pot hole or a curb etc.. the rim doesnt seem bent from the pic but that tire is deff deformed before spending any more money on bearings etc try a different tire you have lyin around
Old Mar 23, 2008 | 05:29 PM
nineohnine's Avatar
lol that dent is normal.. its part of the manufacturing process AND is very common in those tires (i work at walmart tire and lube center we sell those ) i see it all the time.. nothing to wory about really .. unless it feels really squishie and is sticking outwards... hpe thsi helps with your search...
Old Mar 23, 2008 | 05:37 PM
FBS's Avatar
FBS
Default Re: Why the hell is my car so loud at speed? (nineohnine)
okay. I didn't think it was anything to worry about after doing a bit of googling, but i definitely wanted to check before I ripped anything apart.
anello16
Jul 14, 2009 09:56 AM
MrDomino
May 26, 2008 12:11 PM
Battle Mike
12
Sep 20, 2006 10:20 AM
EK k kay
12
Feb 3, 2005 11:08 PM
noob
Jan 31, 2005 03:38 PM
