What ind of mods can you get away with without voiding Acura's warranty on a Type-S
Old Mar 2, 2008 | 09:41 PM
dasfonzie's Avatar
Default What kind of mods can you get away with without voiding Acura's warranty on a Type-S
Once I sell the cars I have now I want to get an RSX Type-S, but I'd like to put a little extra pep in it, as it wouldn't be my DD. I want to get it putting like 230-250 to the wheels.
So would it be worth it to pay a little extra for the face lifted model, with a warranty if I want to mod it, or would it be a waste since the mods would void the warranty?
Old Mar 2, 2008 | 10:24 PM
dasfonzie's Avatar
Default Re: What kind of mods can you get away with without voiding Acura's warranty on a Type-S (dasfonzie)
Also, is it possible to swap the front end and headlights from an 05/06 on to the earlier model?
Old Mar 2, 2008 | 11:56 PM
rawNArsxS's Avatar
yes, 05-06 headlights and tailights can be swapped onto the 02-04 models. im sure you'll find somthin on it if u search.
Old Mar 3, 2008 | 02:14 AM
risktypeS's Avatar
it depends what you are doing to the car. Some dealerships wont care to an extent and others will not touch your car because you modded it (which they really can't do because they have to proof that mod voids the warranty).
Yes the 05-06 lighs will fit on the 02-04. The tail lights you will have to do a little modding to make them fit from what i hear. You'd have to drill into your car at a certain area to make the taillights fit flush in.
Old Mar 3, 2008 | 06:52 AM
Tyte-S's Avatar
Default Re: What kind of mods can you get away with without voiding Acura's warranty on a Type-S (risktypeS)
The mods you will need to do to reach 250 to the wheels will most likely void your warranty.
Old Mar 3, 2008 | 04:49 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: What kind of mods can you get away with without voiding Acura's warranty on a Type-S (Tyte-S)
they can only void your warranty if the part actually causes the problem. read the Magnuson-Moss Warranty Act or just do a search on google and it'll paraphrase it for you. of course if you go put a turbo on your car it'll be totally different.
Old Mar 3, 2008 | 06:30 PM
risktypeS's Avatar
Default Re: What kind of mods can you get away with without voiding Acura's warranty on a Type-S (chadismo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadismo &raquo;</TD></TR><TR><TD CLASS="quote">they can only void your warranty if the part actually causes the problem. read the Magnuson-Moss Warranty Act or just do a search on google and it'll paraphrase it for you. of course if you go put a turbo on your car it'll be totally different.</TD></TR></TABLE>
Old Mar 3, 2008 | 07:25 PM
Tyte-S's Avatar
Anytime the dealership sees aftermarket parts and you bring it in to fix something, they are going to blame the part failure on the mods. I've seen it a hundred times. What parts do you suggest that will yield 250whp that won't void the warranty?
Old Mar 3, 2008 | 07:32 PM
Tyte-S's Avatar
You could go with the Hytech kit, if you go $7500 to blow... Stroker Kit even... Get in the area of 225whp with I/RH/E Kpro and some cams...
JDM_EK_wanabe
Lighting
16
Jan 6, 2012 02:31 PM
Blackline47
Honda Civic (2006 - 2015)
15
May 20, 2007 09:39 AM
Dohc 4door Rye
Sep 26, 2006 04:19 PM
hkshiper
May 6, 2004 06:15 AM
Type Wah
Dec 28, 2002 01:43 AM
