i have a tranny prob.
Old Mar 2, 2008 | 06:03 PM
thedao's Avatar
Default i have a tranny prob.
ok so i bought this eg hatch with a b16 swap, the tranny was working just fine for two days. Then thats when it happend the 5th gear pop out. so that suck for me for about two weeks. then i got a new tranny to replace the old one. that tranny work ok for about three weeks then it happpen 5th came out like crazy. and i know i did a good job swaping the tranny.
Old Mar 2, 2008 | 06:15 PM
thedao's Avatar
why dose my 5th keep coming out...
Old Mar 3, 2008 | 10:53 AM
Dan8yourV8's Avatar
Default Re: (thedao)
that happened to me but mine was cuz i broke one of the pucks of the 6 puck clutch i had in it
Old Mar 3, 2008 | 10:55 AM
Dan8yourV8's Avatar
Default Re: (Dan8yourV8)
wish you the best of luck with that could always take it to a tranny shop to tar it apart and just check everything to make sure everything is good
Old Mar 3, 2008 | 11:12 AM
blwn95civic's Avatar
shift linkage issue? Sounds like your not getting the car all the way in gear. I doubt you'd have two different trannys have the same problem.
Old Mar 3, 2008 | 12:04 PM
Blk00EJ8's Avatar
Default Re:
If it wasn't all the way in gear it would grind once the clutch was released. I'm inclined to say that it was just bad luck and you got 2 bad trans back to back.
Old Mar 3, 2008 | 12:28 PM
stock99si's Avatar
did you get a whining noise in your tranny?
Old Mar 3, 2008 | 09:47 PM
thedao's Avatar
nope it didn't make any noise. i know that it goes in gear. when i rest my hand on the shift **** i can feel it popping out slowly.
Old Mar 3, 2008 | 10:34 PM
obuhmyuh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedao &raquo;</TD></TR><TR><TD CLASS="quote">nope it didn't make any noise. i know that it goes in gear. when i rest my hand on the shift **** i can feel it popping out slowly.</TD></TR></TABLE>
that happened on my d-series tranny 3rd and 5th wouldnt stay in place and would pop out. could be your fork... i swapped trannys and my prob was solved..
Old Mar 3, 2008 | 11:04 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (d[sick]sTeena)
One of the first signs of LOW TRANSMISSION FLUID in a b-series transmission is the gearshift popping out of gear, especially in fifth.
Check your levels.
Old Mar 4, 2008 | 02:44 AM
sleepermotor's Avatar
Banned
Default Re: i have a tranny prob. (thedao)
its probaly something wrong wit the motor
Old Mar 4, 2008 | 06:38 AM
Blk00EJ8's Avatar
Default Re: i have a tranny prob. (sleepermotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepermotor &raquo;</TD></TR><TR><TD CLASS="quote">its probaly something wrong wit the motor</TD></TR></TABLE>
wtf
cfrank89
21
Nov 27, 2011 05:42 AM
boostinnc
Transmission & Drivetrain
Jan 2, 2010 01:37 PM
eg grom
Jun 18, 2009 09:21 PM
OldSchoolCrxSiR
Aug 5, 2002 07:12 AM
