"i hear dead people": suspension squeaking on DA
Old Mar 1, 2008 | 09:40 PM
leroyb's Avatar
Default "i hear dead people"
ok i just bought a 93 da the car is clean i guess but the only thing that bother me from it is that it squeaks a lot its like from the suspension i'm guessing..any one know wat to do they told me to change the bushings but i have no idea how to do that
Old Mar 1, 2008 | 10:24 PM
SuckMyDOHC's Avatar
either search or bring it to a shop
Old Mar 2, 2008 | 09:54 AM
solid gsr's Avatar
usually it ball joints when it is a squeak on a DA, it can be strut mounts, hatch not down tight, you gotta be more specific
Old Mar 2, 2008 | 10:11 PM
leroyb's Avatar
Default Re: "i hear dead people" (leroyb)
well when i drive around mostly this is the suspention it has the hatch is locked down good so cant be that i'm taking a wild guess and i think is that strut bar in the trunk
Old Mar 3, 2008 | 12:20 PM
Colin's Avatar
If you're running stiffer than stock spring rates and getting a squeak from the rear, there's a good chance it's the hatch.
It sounds strange, but open up your hatch, look up and find the metal "loop" on the hatch which locks into the latch on the car. Take some electrical tape and wrap it around this "loop". 2-5 wraps should be fine. This should significantly quiet down your hatch, but you'll need to replace the tape every so often.
This might not be your only problem, but it is a common one.
Old Mar 3, 2008 | 10:52 PM
leroyb's Avatar
Default Re: "i hear dead people" (Colin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroyb &raquo;</TD></TR><TR><TD CLASS="quote">ok i just bought a 93 da the car is clean i guess but the only thing that bother me from it is that it squeaks a lot its like from the suspension i'm guessing..any one know wat to do they told me to change the bushings but i have no idea how to do that </TD></TR></TABLE>
alright ill give that a try thankx
Old Mar 4, 2008 | 06:10 AM
lmike6453's Avatar
if you want you can keep checking up on my thread
https://honda-tech.com/zerothread?id=2238032
Neomoogle
Nov 6, 2011 03:04 PM
JasonKarl
Sep 28, 2007 10:55 PM
Burke
Oct 15, 2003 04:14 AM
LOwrestling2001
Mar 9, 2003 11:39 PM
