JDM 98 Spec B18C-R N/A build... help!
Old Mar 1, 2008 | 08:06 PM
forcefedsi's Avatar
Default JDM 98 Spec B18C-R N/A build... help!
Hey all, I am looking to make some more power this season and I started to piece together a turbo build for this R motor. I just wanted to run 6-7 psi in stock form but I am pretty worried about the reliability of boosting a 11.5:1 (I think) CR motor on 94 octane pump gas. Anyhow, I was thinking of going all motor because I think It would be a much more reliable option and I could probably run the same 1/4 times with a good setup.
The motor needs rings, the compression in cylinder #3 is way down. It runs healthy it just burns a bit of oil in Vtec. Anyhow, I am going to be rebuilding it either for boost or N/A and I was wondering what I can do to try to make around 220-230 WHP N/A, keeping in mind that I am able to change all of the internals in the motor. I just need this to be a reliable daily driver that I can have some fun with. The motor made 187whp/130wtq completely untuned with just I/H/E on a dynojet so I think I can make some good power out of it. Any input is appreciated, I'm looking for specifics parts to use and general upgrades I will need, thanks.
Old Mar 1, 2008 | 10:57 PM
RagingAngel's Avatar
Default Re: JDM 98 Spec B18C-R N/A build... help! (forcefedsi)
you need to search.
look for posts created by b19coupe
archived and recent.
Old Mar 2, 2008 | 03:32 PM
forcefedsi's Avatar
Default Re: JDM 98 Spec B18C-R N/A build... help! (RagingAngel)
I've been searching and I haven't found anything or anyone using the ITR motor. I'm not that great at navigating thorugh this site... I also know that I don't want to frankenstein this into an LS/VTEC or CRVTEC.
Old Mar 2, 2008 | 03:40 PM
Combustion Contraption's Avatar
2 things...
1. It is not very common for one cylinder to be way down on compression compared to another due to rings.
2. Why no ls/crvtec?
Old Mar 2, 2008 | 06:24 PM
forcefedsi's Avatar
Default Re: (Combustion Contraption)
Well I wanted to keep the motor intact because it is an R motor... I'm not 100% on whats wrong with the motor I know, I'm just assuming it isn't anything serious (im hoping valve seals or piston rings) because the motor does run very very strong.
Old Mar 2, 2008 | 06:58 PM
forcefedsi's Avatar
although if it would be really beneficial, I could get my hands on a b20z or b20b motor for pretty cheap (b20z im assuming is preferable because of the higher compression?)
thank you for your help thus far.
Old Mar 2, 2008 | 07:06 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedsi &raquo;</TD></TR><TR><TD CLASS="quote">I've been searching and I haven't found anything or anyone using the ITR motor. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1415895
https://honda-tech.com/zerothread?id=1768567
https://honda-tech.com/zerothread?id=151363
There are lots of people using ITR motors.
Old Mar 2, 2008 | 08:44 PM
forcefedsi's Avatar
Default Re: JDM 98 Spec B18C-R N/A build... help! (b19coupe)
thanks a lot... im pretty bad at navigating this site.
chasered07
Feb 23, 2010 02:58 PM
twentyhurtz
24
Dec 30, 2008 12:43 AM
Doostur
Oct 1, 2004 03:51 AM
not133t
Oct 3, 2003 11:19 AM
F120man
Jul 26, 2001 01:02 PM
