Suspension & Brakes Theory, alignment, spring rates....
Suspension parts for 94 del sol
Old Mar 1, 2008 | 06:32 PM
corince06's Avatar
Default Suspension parts for 94 del sol
i am totally upgrading my suspension and was wondering if anyone could give me tips on what brands to buy for the following items for the best handling capabilities
struts and coil overs
lca's
sway bars
sub frame support
thank you
Old Mar 1, 2008 | 10:04 PM
Stoich EG2's Avatar
Default Re: Suspension parts for 94 del sol (corince06)
1. what is your price range?
2. what is the intended use of the car?
3. what is the intended use of the car?
4. what is your price range?
Old Mar 2, 2008 | 06:55 AM
corince06's Avatar
Default Re: Suspension parts for 94 del sol (Stoich EG2)
dont really care about price. i just want the best parts. i plan on using it for road racing and drag strips around the area
Old Mar 3, 2008 | 03:03 PM
circuitEG6's Avatar
i have an EG hatch
-Omni Power coilovers nitrogen filled damper with F600lb/R900lb spring rates respectively
-Skunk 2 upper front control arms and rear LCA'S, rear camber kit
-Beaks rear lower tie bar
-Energy Suspension bushings all around
-Spoon front and rear strut tower bars
The car handles EXCELLENT with 3 degrees neg. camber and a slight toe-out in the front and 1 degree neg. camber in the rear
Sivartus
Apr 10, 2019 04:38 PM
JC_1118
Dec 14, 2012 08:51 AM
96johnson
Suspension & Brakes
Apr 14, 2009 09:16 PM
spaceman00
10
Apr 23, 2007 02:23 PM
spacemanspiff
Dec 28, 2002 11:01 PM
