CEL 1 Blink = O2 Sensor 1, quick question
Old Mar 1, 2008 | 04:43 PM
ekcivic9's Avatar
Default CEL 1 Blink = O2 Sensor 1, quick question
heyya HT'ers
i recently had a cel thrown when i was driving, caused a short idle problem. but i still drove on it till this weekend.
i pulled the code by using the method in the sticky, and i just saw one blink from the CEL.
according to the code list, one blink means its the o2 sensor #1.
is this the o2 sensor going into the headers, or the one by the cat?
btw i drive a 96 civic ex, d16y8. ive been getting ~26mpg, could it be the o2 causing this?
thanks
Old Mar 1, 2008 | 06:49 PM
TylerB's Avatar
Default Re: CEL 1 Blink = O2 Sensor 1, quick question (ekcivic9)
Are you positive it's not 10 instead of 1? IIRC, #1 is in the manifold
Old Mar 1, 2008 | 07:48 PM
ekcivic9's Avatar
it was just one blink, i couldnt tell if it was short or long since it blinked just once.
Old Mar 1, 2008 | 07:54 PM
z6hatchboy's Avatar
Default Re: (ekcivic9)
Well since you have a ej8, i think you just have one o2, the primary, right? If so how many miles is on the car. Its a 1=o2 or a 10=iat. A short blink is pretty short (.5 sec) it shouldnt be too hard to tell.
Old Mar 1, 2008 | 08:32 PM
ekcivic9's Avatar
z6 - as soon as i turn they key, the light blinks then stays on. it doesnt seem like a long blink like the ones ive seen on youtube vids.
i have about 130K on my ej8, and im not sure if the previous owner has replaced the o2's.
is it a quick DIY fix?
Old Mar 1, 2008 | 08:49 PM
97Ej6mike's Avatar
a bad primary 02 would certainly kill gas mileage. ECU relies on it to see whats being burned in order to decide how rich/lean to run the motor. When that goes bad, it automatically starts throwing in more fuel than needed. Sometimes o2's can become clogged over time with soot/carbon buildup, which in some cases can cause the ecu to think it isnt reading, therefore throwing a CEL. This can be solved by simply removing the sensor and cleaning it off with a touch of brake-cleaner and a rag. Otherwise, its time for replacing them.
Old Mar 1, 2008 | 09:48 PM
ekcivic9's Avatar
thanks 97Ej6mike, I will try to clean it before i replace it!
traxxasx
Apr 16, 2008 06:34 AM
draxxus07
Sep 24, 2005 12:10 PM
FastNFurious
Mar 24, 2004 11:36 PM
Qwikrex
Jul 29, 2002 10:45 AM
Qwikrex
Jun 22, 2002 01:04 AM
