Need help chipping ECU
Old Mar 1, 2008 | 04:13 PM
dragonkx's Avatar
Default Need help chipping ECU
I have a jdm b16, with a jdm p30 ecu. I need to know how i can chip it or prepare it to be dyno. Ive compared the ecu to the USDM ecu and its different, so i need some help.
Old Mar 1, 2008 | 04:44 PM
GhostAccord's Avatar
Default Re: Need help chipping ECU (dragonkx)
JDM ECU's have what are known as surface mounted components, chips, resistors switches...etc. Surface mount soldering is not something to try for a first time ECU soldering job. The USDM ECU's have thru-hole components these are easier to handle as they go through the board and are soldered from the back side.
If you are not familiar with the differences between surface mount and thru-hole soldering. I would suggest that you take your ECU to someone who knows how to do it.
If you know how to surface mount solder and you are just looking for the part numbers and a guide check out PGM-FI.
http://web.archive.org/web/200...DMP30
Old Mar 1, 2008 | 05:16 PM
zccr-xsi's Avatar
just little advice if u nevert soldered or desoldered i would try this at home!!!!!!!!
Karl Kluth
Oct 8, 2017 06:44 PM
Revi
Oct 11, 2006 03:15 PM
Steemo
10
Jun 3, 2004 11:50 PM
93SIRII
Aug 31, 2003 01:27 PM
