eg clusters
Old Mar 1, 2008 | 02:49 PM
kyorishin's Avatar
Default eg clusters
why are the eg cluster so **** to malfuction i gone through 2 now and its all the same either the gas stops reading correctly or the speedo stops working, i know this cuase i tested mine with a working one and got the same results anyways jsut wondering and if instead of always buying new ones is there a way to fix them?
Old Mar 1, 2008 | 03:55 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: eg clusters (kyorishin)
replacing just gauges or whole clusters? replacing with brand new? or another used one that is prone to failure?
Old Mar 1, 2008 | 04:20 PM
kyorishin's Avatar
well my very first cluster was a cx cluster but i wanted a tach so i swaped out the whole cluster for a ex cluster and swapped over my old speedo, worked for a good while then the whole cluster just went speedo/fuel, so i bought a new cluster worked then this time speedo went, it was more it would come on and off with no pattern, my vss was good the whole time and i swapped over a working cluster to make sure it wasnt my vss. so jsut wondering why the speedos are so prone to malfucntions
Old Mar 1, 2008 | 04:39 PM
BlueIntegraBoy's Avatar
Retighten all the screws behind the gauges.
Old Mar 1, 2008 | 04:45 PM
kyorishin's Avatar
tried dat even cleaned all teh connections with rubbing alcohol nothing happen
Old Mar 1, 2008 | 07:01 PM
kyorishin's Avatar
bump
eg6REDmilano20
Jan 11, 2010 01:35 PM
msinsky14
12
Mar 1, 2006 07:36 PM
