eg clusters
why are the eg cluster so pron to malfuction i gone through 2 now and its all the same either the gas stops reading correctly or the speedo stops working, i know this cuase i tested mine with a working one and got the same results anyways jsut wondering and if instead of always buying new ones is there a way to fix them?
Re: eg clusters (kyorishin)
replacing just gauges or whole clusters? replacing with brand new? or another used one that is prone to failure?
well my very first cluster was a cx cluster but i wanted a tach so i swaped out the whole cluster for a ex cluster and swapped over my old speedo, worked for a good while then the whole cluster just went speedo/fuel, so i bought a new cluster worked then this time speedo went, it was more it would come on and off with no pattern, my vss was good the whole time and i swapped over a working cluster to make sure it wasnt my vss. so jsut wondering why the speedos are so prone to malfucntions
Retighten all the screws behind the gauges.
tried dat even cleaned all teh connections with rubbing alcohol nothing happen
bump
