95 b18c1 motor in 93 civic coupe
Old Jul 6, 2002 | 01:18 PM
sircivic's Avatar
Default 95 b18c1 motor in 93 civic coupe
this swap i was told was easy, but I must say, it is def not as easy as i thought. i bought the motor from a shop, and they said since my civic is an ex, and it is obd1, and so is the 95 GSR motor, it should be plug and play simple. well, i must tell you, this is crap, unles i'm stupid. the motor slid in the car in about 20 mins, but i'm having troublw with the power steering, and throttle. can someone give me a list of parts to get, and items i need to get this swap to work. thanks.
[Modified by sircivic, 10:18 PM 7/6/2002]
Old Jul 6, 2002 | 03:35 PM
JV's Avatar
JV
Who?
Default Re: 95 b18c1 motor in 93 civic coupe (sircivic)
Your question is kinda choppy so i'll just give you a whole run down:
Motor
Trans
Axles
ECU
Shiftlinkage
Mounts (You can use all the stock civic rubber EXCEPT the timing belt mount)
Throttle cable
Powersteering pump (Your lines should bolt up to the pump from a B18)
Also try this: http://tech.hybridgarage.com/tech/index.html
akad3mikz
Apr 5, 2005 11:29 PM
bumpin_bass
Apr 9, 2002 10:27 AM
RTRcivic
Oct 31, 2001 10:04 AM
