Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Idle Problem 01 Civic Ex. (searched)
Old Feb 29, 2008 | 04:37 PM
H0ndas g0 Vr00m's Avatar
Default Idle Problem 01 Civic Ex. (searched)
I just did a search and nothing helped really.
Its been going on and off for a while now. My CEL light will come on sometimes and then go off without me resetting it.
Problem: When im driving everything is normal. But when i start the car, let it idle, or stop at a light in neutral my RPMs will be around 1500, surge up to about 1700, go on like this for a few seconds and then drop back down to normal after it stops surging.
Any ideas on what needs to be done? I have a warm day tomorrow (in Michigan) so i might be able to solve the problem. This is my FIRST honda so im not really sure what im doing.
Thanks for your help.
Ps. Pictures would be WONDERFUL if you reply!!!
Old Feb 29, 2008 | 07:00 PM
toyomatt84's Avatar
Sanji
It could be your idle air control valve (it may be clogged, or the controller could have gunk in it).
Old Feb 29, 2008 | 09:18 PM
Default Re: (toyomatt84)
Any idea where it is?
Old Mar 1, 2008 | 04:03 AM
fongyz22's Avatar
Default Re: (H0ndas g0 Vr00m)
https://honda-tech.com/zerothread/2235426
this could be another possibility fitting some symptoms you've described.
it's a more recent thread posting, but a rare case on these civics according to the thread.
Old Mar 1, 2008 | 07:37 AM
tlendt's Avatar
Default Re: Idle Problem 01 Civic Ex. (H0ndas g0 Vr00m)
I'm guessing Matt is dead-on. The IAC is in the throttle body and provides a bypass when the throttle is closed, to finely control the air/fuel ratio at idle. In Iowa where I live ethanol blended fuels are popular (corn, go figure) and we see this causing a gumming of IAC's on vehicles of all mfr. I teach vocational auto mechanics and have seen it on every make of car. The good part is you can usually access the part quite easily and clean it with 20 cents worth of carb cleaner. Cheap and easy and worth a try.
Old Mar 3, 2008 | 09:40 AM
Does anyone know where the IAC is located?
Im trying to find it so that i can clean it and i cant find it AT ALL!!!
And i have a nice 45 degree day in Michigan so today is the perfect day to find my exhaust leak and clean this part.
Thanks!
Old Mar 3, 2008 | 10:08 AM
toyomatt84's Avatar
Sanji
Part #1 in this picture:
It's that assembly attached to the Throttle Body.
Old Mar 3, 2008 | 10:27 AM
THANK YOU!!!!!!!!!!!
Thats what i thought it was but i wasnt sure.
Old Mar 3, 2008 | 10:34 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndas g0 Vr00m &raquo;</TD></TR><TR><TD CLASS="quote">THANK YOU!!!!!!!!!!!
Thats what i thought it was but i wasnt sure.</TD></TR></TABLE>
Not a problem. Sorry it took a bit, but I've been rather busy recently.
Old Mar 3, 2008 | 12:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
Not a problem. Sorry it took a bit, but I've been rather busy recently.</TD></TR></TABLE>
Its not a problem at all. We are all busy at some point. Thanks for getting back to me.
Old Mar 3, 2008 | 02:36 PM
Well sad to say i was out there for about a half hour trying to get the THREE screws that hold it on off. and i still cant get it off. Im pissed.
Old Mar 3, 2008 | 02:37 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndas g0 Vr00m &raquo;</TD></TR><TR><TD CLASS="quote">Well sad to say i was out there for about a half hour trying to get the THREE screws that hold it on off. and i still cant get it off. Im pissed.</TD></TR></TABLE>
Have you tried using PB Blaster?
Old Mar 3, 2008 | 09:57 PM
Come again? Where can i get it/what is it?
Old Mar 3, 2008 | 10:00 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndas g0 Vr00m &raquo;</TD></TR><TR><TD CLASS="quote">Come again? Where can i get it/what is it?</TD></TR></TABLE>
It's a metal penetrator, that breaks down rust and corrosion. It'll help free up the bolts on the IAC valve. You can get it at places like True Value and ACE Hardware.
Old Mar 3, 2008 | 10:06 PM
Cool, ill be sure to get that when i get a nice day within the next two weeks...its supposed to snow and be below freezing....i HATE when spring taunts me with a nice day...
Thanks for your help Toyomatt84.
Old Mar 3, 2008 | 10:35 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndas g0 Vr00m &raquo;</TD></TR><TR><TD CLASS="quote">Cool, ill be sure to get that when i get a nice day within the next two weeks...its supposed to snow and be below freezing....i HATE when spring taunts me with a nice day...
Thanks for your help Toyomatt84.</TD></TR></TABLE>
I feel your pain, really. This weekend we had 40+ degree weather. Today, snow and 15 degrees. This region sucks.
Old Mar 5, 2008 | 04:46 PM
bikerballrEM2's Avatar
also check ur spark plugs. i had that issue and one of my plugs was loose and burnt up the coil. after i replaced the coil and tighted up the spark plug the problem was gone
Old Mar 11, 2008 | 07:53 PM
I found out what it was.
My header had become loose right above the first o2 sensor which was why it was throwing the code and the problem with the idle. I tightened it up and i havent thrown a code or had the problem since. Its been about a good solid week and a half.
w00t!
MyEj1Broke
Jan 10, 2014 08:09 AM
DO/\/\O
14
May 9, 2011 05:56 PM
fergs96integra
Nov 8, 2010 09:40 PM
kamakaze1
Nov 3, 2005 06:02 PM
ITLNstallion818
Jun 18, 2005 02:56 PM
