Car has no electrical power
Old Feb 29, 2008 | 11:30 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Car has no electrical power
I need some help trouble shooting.
I replaced the battery, the ground and power wiress, and the starter. The odd thing is I have no internal or external lights. Also, when I check across the battery terminals I have 12.6 volts. When I check at the starter, it reads 2 volts. Any suggestions?
Old Feb 29, 2008 | 11:32 AM
fourdOOrEF2_F.D.W's Avatar
Default Re: Car has no electrical power (mar778c)
the main FUSES??? check the fuse box in the bay on the left!
Old Feb 29, 2008 | 11:50 AM
mar778c's Avatar
Community Builder
Default Re: Car has no electrical power (fourdOOrEF2@FDW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourdOOrEF2@FDW &raquo;</TD></TR><TR><TD CLASS="quote">
the main FUSES??? check the fuse box in the bay on the left!</TD></TR></TABLE>
Yeap, I checked those and drivers side in the cabin . They are all good.
The problem is I read 2 volts at any point in the fuse box.
Old Feb 29, 2008 | 06:10 PM
alscrx's Avatar
Check your + battery cable. If your battery reads 12v, then its probably a fuse.
Your starter will read 12v when cranking!
Your headlight and interior dash lights are on 3 seperate fuses which unless you seriously shorted something out, I doubt will all be blown.
Check the power cable again.....something is not making sense here
Old Mar 1, 2008 | 05:49 AM
mar778c's Avatar
Community Builder
Default Re: Car has no electrical power (alscrx)
It turns out my grounds were shot.
Everybody, remember to clean your grounds once a year.
BrandonPell
Aug 30, 2018 11:03 AM
bennjamin@ozhonda.com
Sep 4, 2006 05:20 AM
ITR9788
Oct 13, 2005 01:34 PM
ILOVEGIRLS
Feb 23, 2004 03:30 PM
