Lightest/least complex/easiest to find/cheaper to buy Honda engine?
Old Feb 28, 2008 | 08:27 PM
erevlydeux's Avatar
Default Lightest/least complex/easiest to find/cheapest to buy Honda engine?
My problem is two-fold: I want to find a cheap 4-cylinder engine that I can tear down and rebuild so I can learn about car engines, but I also want one that I can use to build my very own gixxerkart-esque type vehicle.
Naturally, 4-cylinder performance would be Honda, all the way. However, I do not have any working knowledge about the specifics of any of Honda's 4-cylinder engine series (weight, power output, how many produced/what cars they were put in, VTEC or non-VTEC, etc) and thus I turn to you, Honda-Tech, to hopefully point me in the right direction, and give me some needed insight.
As stated above, I'm looking to build a gixxerkart-esque vehicle, so smaller displacement and lower weight is both OK/preferred. Since I plan to tear down/rebuild this engine myself, complexity would be bad, and thus I'm not sure if I'd want to walk down the VTEC path. I'd like something that I could pickup easily, without having to go through some JDM junkyard guy in Japan or something, and low cost is important as I'm only a lowly college student.
So, what suggestions can you give me?
Thanks in advance.
Old Feb 29, 2008 | 03:03 AM
1net's Avatar
maybe a motorcycle engine is your best choice, but since this thread is about car engines, I'd suggest
one of these: D16A6, D15B7, or D15B2
All of them are pretty basic engines and all of them can be converted to sohc vtec later on. btw, the vtec itself is nothing fancy, don't get scared.
Old Feb 29, 2008 | 11:34 AM
erevlydeux's Avatar
Default Re: (1net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1net &raquo;</TD></TR><TR><TD CLASS="quote">maybe a motorcycle engine is your best choice, but since this thread is about car engines, I'd suggest
All of them are pretty basic engines and all of them can be converted to sohc vtec later on. btw, the vtec itself is nothing fancy, don't get scared.</TD></TR></TABLE>
Alright, so they are all simple to start, but I could convert them to VTEC later on as a step-up; sounds good. How readily available are these engines?
Old Feb 29, 2008 | 08:25 PM
KENetics1's Avatar
Default Re: Lightest/least complex/easiest to find/cheapest to buy Honda engine? (erevlydeux)
local junkyards. find a ef or newer honda, take out motor. should be cheap.
powerpuff
Nov 1, 2013 11:50 AM
Jimmyac28
Feb 7, 2013 03:00 PM
kirbyno1
Jun 19, 2009 04:25 AM
robAP
Jul 4, 2006 06:53 AM
