No Crank and no nothing
Old Feb 28, 2008 | 04:30 PM
Import_spoon's Avatar
Default No Crank and no nothing
Heres the problem I tried to start my car and all I heard was a click and after that no start. It didn't crank nor the dash lights light up. Its like a car with no engine. Nothing works, I never ran into this problem so I don't know whats wrong. I did a little searching already. I was thinking it was the main relay but I looked at that but all I read was about gas so I don't know if its really the main relay anymore. Alternator, Starter??? If you have encountered this please let me know because its my only car. Thank you
Car is a 93 Civic with a D16z6 motor in there.
Old Feb 28, 2008 | 04:39 PM
instrument's Avatar
if it literally does nothing its probably a ground.
Old Feb 28, 2008 | 07:27 PM
Alright then will check tomorrow after work. Thanks. I am pretty sure its a ground too because no electricity means maybe positive is plugged but negative is not.
Old Feb 28, 2008 | 07:31 PM
97ekb18b's Avatar
Default Re: (Import_spoon)
no by no grounds he means engine grounds it obviously has a battery ground because it wouldnt click if it didnt, try rolling the car and see if it starts like have some one push it and then u try and turn the key on ifthe lights light up its a ground, my old crx did exactly this and i ended up finding out it was a ground by moving the vehcial and starting it, im guessing the axles created enought of a ground to start idk lol
Old Feb 28, 2008 | 07:45 PM
ender214's Avatar
I had a similar problem then i just smacked the starter soleniod with a hammer and it has worked just fine.
Old Feb 28, 2008 | 08:39 PM
Default Re: (97ekb18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">no by no grounds he means engine grounds it obviously has a battery ground because it wouldnt click if it didnt, try rolling the car and see if it starts like have some one push it and then u try and turn the key on ifthe lights light up its a ground, my old crx did exactly this and i ended up finding out it was a ground by moving the vehcial and starting it, im guessing the axles created enought of a ground to start idk lol</TD></TR></TABLE>
I would like to do push start but what I don't like about that is because the car needs to drive up a steep hill to put in the garage and thats a bitch. If it starts its good but if it doesn't then it sucks. I will think about the push start.
Old Feb 28, 2008 | 08:40 PM
Default Re: (ender214)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ender214 &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem then i just smacked the starter soleniod with a hammer and it has worked just fine.</TD></TR></TABLE>
What sucks is that it doesn't even crank nor the lights in the dash light up.
Old Feb 28, 2008 | 08:46 PM
thatonekid's Avatar
it might be the starter, use jumpers and try to start it happend to my moms 94 civic, if thats not the problem let me know what it is i wanna learn this stuff
Old Feb 28, 2008 | 08:56 PM
dr.garagetuner's Avatar
start by first checking to make sure the ground connections are good and tight and the grounds in the engine bay area also. second check to see if the starter connections are tight also. if they are loose they can cause it to have high resistance resulting in no cranking. or u can always take ur battery and starter to autozone and have them checked for free.
Old Feb 28, 2008 | 08:57 PM
-Gary-'s Avatar
Always check the easy stuff first.
Try the main 80 amp fuse.
Old Feb 28, 2008 | 08:58 PM
DCSportEJ1Civic's Avatar
Default Re: (dr.garagetuner)
this may be a stupid question but no one has addressed it, unless i missed it. but did you check your battery voltage. to me it sounds like a dead battery.
Old Feb 28, 2008 | 09:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon &raquo;</TD></TR><TR><TD CLASS="quote">
I would like to do push start but what I don't like about that is because the car needs to drive up a steep hill to put in the garage and thats a bitch. If it starts its good but if it doesn't then it sucks. I will think about the push start.</TD></TR></TABLE>
if it is your battery a push start will do nothing until the battery has a charge. the alt. will not be turning fast enough to start it.
Old Feb 28, 2008 | 10:24 PM
97ekb18b's Avatar
Default Re: (DCSportEJ1Civic)
im not telling you to "push start it" im just saying push it back and forth 5 feet or so while ur in it and see if it creates a good enought engine ground to light ur dash **** up
Old Feb 28, 2008 | 10:29 PM
obuhmyuh's Avatar
x2 on the battery, could be a ground, or even a short circuit. i had my coolant temp wires cut and spun together (so the circuit was closed), the wires came apart one day and when i tried to start my car it just kinda clicked once. and i found that those wires came apart, spun em back together and it started no prob.
silez
May 1, 2014 03:55 AM
lingochad
14
Oct 15, 2012 04:00 PM
J_ron
19
Dec 24, 2009 06:39 AM
snoopy_11
Jan 30, 2007 12:42 PM
ck123
Jun 16, 2006 09:58 PM
