help with mpfi swap cel 4 for crank angle sensor
Old Feb 28, 2008 | 04:21 PM
grg9988's Avatar
Default help with mpfi swap cel 4 for crank angle sensor
I just put a b20 in my ef hatch and i started it for the first time and got a code 4 which is for the crank angle sensor. any feedback is appreciated
Old Feb 29, 2008 | 11:31 AM
rustbucketrex's Avatar
Default Re: help with mpfi swap cel 4 for crank angle sensor (grg9988)
My code 4 came from a bad connection at the ECU, the tab on the wire that hooks to the ECU pin was not holding tight enough for good connection. Don't buy a distributor (like I did) before checking your wiring.
Old Feb 29, 2008 | 12:13 PM
JapJunkie's Avatar
Default Re: help with mpfi swap cel 4 for crank angle sensor (rustbucketrex)
Most of the time I have gotten Crank Angle on swaps its the wiring. Check the wiring.
4drboostking
May 19, 2015 02:37 AM
vtec93accord
Apr 4, 2008 05:24 PM
vtec93accord
Apr 4, 2008 04:01 PM
90h22acrx
Oct 8, 2004 07:58 PM
milruner
Dec 14, 2003 06:48 PM
