main bearings
you'll need to look at your crankshaft and the bottom of your block to know for sure what colors to get. we can not tell you the colors unless u know the letters and numbers on your crank and block.
there should be a chart in there about the main bearings. just match up the numbers and letters from your crankshaft and the bottom of the block...should be
on your stock rods...there should be numbers on the side where the cap bolts onto the rest of the rod. you match those numbers up against the crankshaft to find out what colors you need.
