Type R Oil Pump leak....
Old Feb 28, 2008 | 08:28 AM
emotionisdead's Avatar
Very Emergency!!
Default Type R Oil Pump leak....
I just installed an ITR oil pump on one of my customer's B18B powered hatch and now there is a very wierd oil leak. The leak is coming from the top upper corner. Right where the hex nut thing is. All my bolts are torqued to spec. I didn't even think oil could leak from there. Any help would be great, thanks.
Old Feb 28, 2008 | 09:44 AM
Runnerdown's Avatar
Default Re: Type R Oil Pump leak.... (emotionisdead)
is the plug leaking or where it seals against the block?
Old Feb 28, 2008 | 10:24 AM
TODAwhore's Avatar
Default Re: Type R Oil Pump leak.... (Runnerdown)
yeah their are two different size O-rings..that go there. Hope you got the right one.
Old Feb 28, 2008 | 10:42 AM
NUISANCE's Avatar
Default Re: Type R Oil Pump leak.... (TODAwhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAwhore &raquo;</TD></TR><TR><TD CLASS="quote">yeah their are two different size O-rings..that go there. Hope you got the right one.</TD></TR></TABLE>
Or did you not use one?
Old Feb 28, 2008 | 12:47 PM
Very Emergency!!
Default Re: Type R Oil Pump leak.... (NUISANCE)
Found it, o-ring fell out during install. I pulled it all out and fixed it.
o-ring&gt;me.......
Thanks for the help dudes!!
Ls_V_TurboSi
May 10, 2006 05:14 AM
SIXTY
Jan 1, 2006 10:42 AM
caspers_hatch
Nov 12, 2005 11:37 PM
shreddinryguy
May 12, 2005 09:54 AM
