Honda MTF - sucks??
Old Feb 28, 2008 | 12:05 AM
johnclaunch's Avatar
Default Honda MTF - sucks??
I bought my car six months used and it was stock. It had Honda MTF in it and I changed it to Redline MTL. The Redline was great. I never had any grind issues and it really made the tranny shift smoothly. When it would go into a gear, it slid in very easily without feeling the gears mesh. I just switched the fluid out this time with Honda MTF. Now, I feel every gear go in and mesh together with the shaft. No grinds, but much more harsh than with the Redline I used prior. Any ideas? I don't like it and I will switch back ASAP, but does anyone know if this is normal feel for a tranny with Honda MTF?
Old Feb 28, 2008 | 03:21 AM
hawaiiancb74's Avatar
Default Re: Honda MTF - sucks?? (johnclaunch)
honda doesnt even use honda fluid.. for the rsx they typicaly will put a syncromesh in to help prevent grinding. i would sugest you put RoyalPurple or amsoil back in it.
Old Feb 28, 2008 | 04:51 AM
blueshark123's Avatar
Default Re: Honda MTF - sucks?? (hawaiiancb74)
GM Syncromesh with friciton modifiers ftw
Old Feb 28, 2008 | 06:41 AM
1986's Avatar
Old mtf sucks, new one is a bit better but i am still not too fond of it. I use GM syncromesh personally. Amsoil is good too
Old Feb 28, 2008 | 04:26 PM
Todd00's Avatar
I said I don't want a title!
You tried the new Honda MTF? It's supposed to be better than the original stuff. It's now made by Idemitsu.
Old Feb 29, 2008 | 04:12 AM
eMpAtHy's Avatar
Default Re: Honda MTF - sucks?? (Todd00)
i need to decide on something to use. i have 20k miles on my car and my tranny is starting to act up. Shifting at 4000 with the clutch pedal down all the way and it'll be real rough getting into 2nd gear sometimes.
Old Feb 29, 2008 | 11:52 AM
WyldRice's Avatar
Honda MTF doesn't suck -at least to my car! She LOVES IT!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">You tried the new Honda MTF? It's supposed to be better than the original stuff. It's now made by Idemitsu.</TD></TR></TABLE>
My gears were grinding so bad at 45K, i thought i needed new synchros...
but i used the new HONDA MTF when i changed mine- and NO MORE GRINDS!
Here's a link- i did a DIY write up about it.
https://honda-tech.com/zerothread?id=2155139
i changed it before Thanksgiving... and i still haven't had any grinding,
and YES! ...it has been -20 BELOW (or colder ) many times this last months.
No issues Yet!
i still do the "1,2,3,4,3,2,1,2,3,4,3,2,1" trick... (damn voo-doo rituals!)
Old Feb 29, 2008 | 12:31 PM
Demonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiiancb74 &raquo;</TD></TR><TR><TD CLASS="quote">honda doesnt even use honda fluid.. for the rsx they typicaly will put a syncromesh in to help prevent grinding. i would sugest you put RoyalPurple or amsoil back in it.</TD></TR></TABLE>
That's retarded to even say. HONDA uses HONDA MTF... Just because some DEALERS don't, doesn't speak for the whole company. The NEW Honda MTF is a lot better and many people are saying good things about it. I like it, I swapped mine and it seems a little better. To each his own.
Old Feb 29, 2008 | 01:04 PM
Default Re: Honda MTF - sucks?? (Demonis)
I don't know if it was the "new" MTF, but it had a green label.
Old Feb 29, 2008 | 10:07 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnclaunch &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if it was the "new" MTF, but it had a green label.</TD></TR></TABLE>
It'll say Idemitsu on it.
Old Feb 29, 2008 | 11:08 PM
It'll say Idemitsu on it.</TD></TR></TABLE>
I didn't check it before I trashed it.
Old Mar 1, 2008 | 07:00 PM
black92DA's Avatar
the old honda mtf has a red cap and the new one has a white cap
Old Mar 2, 2008 | 09:44 PM
Default Re: Honda MTF - sucks?? (black92DA)
Back to Redline MTL! Great stuff. I highly recommend.
Old Mar 3, 2008 | 10:46 PM
mormonboy's Avatar
edit:
did you guys use redline MTF or redline MT-90 ( slightly thicker than regular mtf)
Modified by mormonboy at 12:00 AM 3/4/2008
Old Mar 4, 2008 | 12:22 AM
Default Re: Honda MTF - sucks?? (mormonboy)
I just use the MTL. I once mixed one quart MTL and one quart MT-90, but I noticed no difference from just MTL. Redline states that the MTL is a direct replacement for Honda fluid, so I just use it alone.
Old Mar 6, 2008 | 06:09 AM
BlownSi05's Avatar
Default Re: Honda MTF - sucks?? (blueshark123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueshark123 &raquo;</TD></TR><TR><TD CLASS="quote">GM Syncromesh with friciton modifiers ftw</TD></TR></TABLE>
he speaks the truth. expensive, but very much worth it.
Old Mar 6, 2008 | 06:32 PM
khmerboiracer's Avatar
Default Re: Honda MTF - sucks?? (BlownSi05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownSi05 &raquo;</TD></TR><TR><TD CLASS="quote">
he speaks the truth. expensive, but very much worth it.</TD></TR></TABLE>
i second that..i got mine for 6 bucks a quart..i work a dealership. gm syncro works great.
Old Mar 6, 2008 | 07:47 PM
mormonboy's Avatar
Default Re: Honda MTF - sucks?? (khmerboiracer)
i read somewhere that GM synchromesh as well as the friction modified versions r discontinued.
can you confirm that?
Old Mar 7, 2008 | 08:40 PM
if it were true...amsoil makes the equivalent to the syncromesh..but its not i just bought some.
https://www.amsoil.com/storefront/mtf.aspx
Old Mar 8, 2008 | 07:17 AM
dfwjohnd's Avatar
new honda mtf &gt; insert brand here
Old Mar 8, 2008 | 11:05 AM
Default Re: Honda MTF - sucks?? (dfwjohnd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfwjohnd &raquo;</TD></TR><TR><TD CLASS="quote">new honda mtf &gt; insert brand here</TD></TR></TABLE>
I disagree.
Old Mar 8, 2008 | 11:32 AM
DC5ITR329's Avatar
I had the oil and new honda oil. New one is much better. From me.
Old Mar 8, 2008 | 06:24 PM
thrty8street's Avatar
Default Re: Honda MTF - sucks?? (DC5ITR329)
My honda MTF works great, no complains here.
irollerblade
Mar 22, 2009 10:43 PM
Tex Blackwell
Aug 14, 2004 11:10 PM
G-reX
11
Mar 19, 2003 08:20 AM
Chris y0!
28
Dec 24, 2002 05:23 PM
NighthawkR184
Dec 7, 2001 04:28 PM
