Engine Check after instaling a swap on my 94 Jdm Coupe ???? engine works fine after 6 years ?????
Old Feb 27, 2008 | 11:44 PM
94EJ1Coupe's Avatar
Default Engine Check after instaling a swap on my 94 Jdm Coupe ???? engine works fine after 6 years ?????
Ok well it'e been 6 years since I hooked up My teal Green 2 door Civic Coupe and ever since then I had the Engine Check Light lit up on the dash. hould it help if I buy a Plug From JHPUSA.COM and plug it to my headers. My mechanic said it's a sensor but never had any problems. I just want to see what the real deal is ????????????? any suggestions ??????
Old Feb 28, 2008 | 03:53 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Engine Check after instaling a swap on my 94 Jdm Coupe ???? engine works fine after 6 years ????
You have 1 header not 2. Also whats the check engine light for??? Check the code
Old Feb 28, 2008 | 04:23 AM
x0!'s Avatar
x0!
6 years and you are just now going to fix it?
check the FAQ thread, it tells you how to pull the code and what the code is. good luck
Old Feb 28, 2008 | 07:01 PM
94EJ1Coupe's Avatar
No the very first thing that I did was drop a B16A back in 2002, see back then that was one of the hottest things to do on a honda "B" series engine, so I did. Ever sice then I been a JDM Honda enthusiest. I started with Vision Ambers ext. I bought a "Hyper Rev Magazine and looked for ideas for my Coupe. I knew the JDM scence was going to blow up. I bought and started doing research on alot of things. Fog lights, window Visors and even went on line to see what a true JDM civic looked like . My 94 civic ex is a comple transformation from stock except that its not right handed!!! I'll post some pics up I get alot of heads turning. Next thing is Sportmax rims. that's the new thing that I want
Old Feb 28, 2008 | 07:51 PM
mini-meEj1's Avatar
Default Re: (dj Just Right)
wouldn't that sensor be your o2?
Old Feb 28, 2008 | 08:31 PM
x0!'s Avatar
x0!
they made eg coupes in japan?
Old Mar 1, 2008 | 10:28 PM
94EJ1Coupe's Avatar
Default Re: (x0!)
well, I read that if you wanted a coupe in Japan you needed to get it imported from the states. The funny thing is that i seen pictures of Coupes that are right handed. CHeck this link out...... not the best looking Coupe, but it's from Japan.
http://www.japanese-usedcars-e....html
Old Mar 1, 2008 | 10:30 PM
94EJ1Coupe's Avatar
sorry for the double post, but i also wanted to mention that Coupes are not EG there EJ. Check out your vin and you will see this on it EJ, EG, EK ext...... depending what you have
Old Mar 3, 2008 | 12:12 AM
NOFX's Avatar
H-T White Ops
Default Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! &raquo;</TD></TR><TR><TD CLASS="quote">they made eg coupes in japan? </TD></TR></TABLE>
They had fifth gen Civic coupes in Japan called the Civic Coupe STD. It came with a D16A and had the EJ1 chassis code.
Though not a true EG chassis, there were JDM 5th gen coupes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj Just Right &raquo;</TD></TR><TR><TD CLASS="quote">sorry for the double post, but i also wanted to mention that Coupes are not EG there EJ. Check out your vin and you will see this on it EJ, EG, EK ext...... depending what you have </TD></TR></TABLE>
I think that might have been the point he was trying to make. There's a big chassis list thread already posted which helps out a lot even though I still need to make corrections.
thaoimage
Apr 20, 2009 07:21 AM
b16vt3c
Feb 5, 2009 06:05 AM
Tru2Less
Dec 31, 2007 07:17 AM
TastyTuner
Mar 15, 2006 05:29 PM
