Engine Check after instaling a swap on my 94 Jdm Coupe ???? engine works fine after 6 years ?????
Ok well it'e been 6 years since I hooked up My teal Green 2 door Civic Coupe and ever since then I had the Engine Check Light lit up on the dash. hould it help if I buy a Plug From JHPUSA.COM and plug it to my headers. My mechanic said it's a sensor but never had any problems. I just want to see what the real deal is ????????????? any suggestions ??????
HRD PKR
Re: Engine Check after instaling a swap on my 94 Jdm Coupe ???? engine works fine after 6 years ????
You have 1 header not 2. Also whats the check engine light for??? Check the code
No the very first thing that I did was drop a B16A back in 2002, see back then that was one of the hottest things to do on a honda "B" series engine, so I did. Ever sice then I been a JDM Honda enthusiest. I started with Vision Ambers ext. I bought a "Hyper Rev Magazine and looked for ideas for my Coupe. I knew the JDM scence was going to blow up. I bought and started doing research on alot of things. Fog lights, window Visors and even went on line to see what a true JDM civic looked like . My 94 civic ex is a comple transformation from stock except that its not right handed!!! I'll post some pics up I get alot of heads turning. Next thing is Sportmax rims. that's the new thing that I want
Re: (x0!)
well, I read that if you wanted a coupe in Japan you needed to get it imported from the states. The funny thing is that i seen pictures of Coupes that are right handed. CHeck this link out...... not the best looking Coupe, but it's from Japan.
http://www.japanese-usedcars-e....html
Re: (dj Just Right)
sorry for the double post, but i also wanted to mention that Coupes are not EG there EJ. Check out your vin and you will see this on it EJ, EG, EK ext...... depending what you have
H-T White Ops
Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">they made eg coupes in japan? </TD></TR></TABLE>
They had fifth gen Civic coupes in Japan called the Civic Coupe STD. It came with a D16A and had the EJ1 chassis code.
Though not a true EG chassis, there were JDM 5th gen coupes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj Just Right »</TD></TR><TR><TD CLASS="quote">sorry for the double post, but i also wanted to mention that Coupes are not EG there EJ. Check out your vin and you will see this on it EJ, EG, EK ext...... depending what you have </TD></TR></TABLE>
I think that might have been the point he was trying to make. There's a big chassis list thread already posted which helps out a lot even though I still need to make corrections.
