the right shift linkage???
Old Feb 27, 2008 | 05:28 PM
cky4skater's Avatar
Default the right shift linkage???
I have a 92 civic hatch with an Ls obd1 swap and im not sure what shift linkage is the one i have....recently my shifter has been crap. its a short throw DC and u can pull it up and down slightly when its in neutral....when i looked under the car the whole bar moves! its the bar that connects directly to the shifter.
Old Feb 27, 2008 | 05:33 PM
slacks's Avatar
Default Re: the right shift linkage??? (cky4skater)
bushings maybe?
Old Mar 4, 2008 | 09:15 AM
cky4skater's Avatar
Default Re: the right shift linkage??? (slacks)
yea they said it could be that white ball bushing type deal on the actual shifter....what kind of linkage should i use for this car though
Old Mar 4, 2008 | 09:37 AM
crazyguy's Avatar
u should have 94 and up integra shift linkage and it bolts right on and rough shifting can be the bushings and shifter seat ..etc.
Old Mar 4, 2008 | 09:48 AM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cky4skater &raquo;</TD></TR><TR><TD CLASS="quote">yea they said it could be that white ball bushing type deal on the actual shifter....what kind of linkage should i use for this car though</TD></TR></TABLE>
Make sure you have parts 8 and 11 installed on the shifter ball. Also, idiot check, make sure the bushing #18 is in good shape, you have the collars in the bushing (2x #10), and the bolts underneath the shift console are tightened (2x #26).
Old Mar 4, 2008 | 10:36 AM
instrument's Avatar
from what you're describing i'm gonna guess you have no idea what you're doing.
it may just be loose bolts, if you can manage to get under your car i'd check the "bitch pin" and also the bolts that hold the shifter together.
Old Mar 4, 2008 | 10:44 AM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cky4skater &raquo;</TD></TR><TR><TD CLASS="quote">what kind of linkage should i use for this car though</TD></TR></TABLE>
b series linkage for a b series motor.
Old Mar 4, 2008 | 11:50 AM
Memnoch's Avatar
Default Re: the right shift linkage??? (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
b series linkage for a b series motor. </TD></TR></TABLE>
Not all b series linkage is the same (length of vehicles differ, ie: ef/da/ek) but eg's can use all 94+ b series shift linkage..
Old Mar 4, 2008 | 12:07 PM
Your Name's Avatar
Default Re: (instrument)
#15 might be bad,, it happin 2 me.
Old Mar 4, 2008 | 01:16 PM
Blk00EJ8's Avatar
Default Re: (Your Name)
The shifter moving up and down is going to be caused by something, obviously, on the shifter side and not towards the bitch pin. Loose bolts or crappy bushing is most likely.
Old Mar 6, 2008 | 12:07 AM
cky4skater's Avatar
Default Re: (Blk00EJ8)
they're all tightened down just gonna buy the bushing n hope that it works
civicsi0721
Feb 25, 2009 07:17 PM
Luserkid
11
Jun 30, 2004 04:17 PM
2camsaam
Sep 15, 2003 01:35 PM
SpeedMonkeyRacing
11
Nov 13, 2002 01:32 PM
cleverkellen
Sep 6, 2002 05:56 PM
