Honda S2000 Honda S2000
Skunk2 Turbo cam?
Old Feb 27, 2008 | 04:27 PM
EJ8 GSR-T's Avatar
Default Skunk2 Turbo cam?
Hello,
Question for the day...is anyone running a skunk2 turbo cam? I have an ap1 with 8.8:1 comp pistons....f22 crank....and a paxton supercharger running about 17lbs. I am having some trouble with the valves and it looks like its all going to need to be torn down, and i was thinking about throwing a set of cams in there while its all part...any input?
Old Feb 29, 2008 | 04:38 PM
EJ8 GSR-T's Avatar
Default Re: Skunk2 Turbo cam? (EJ8 GSR-T)
ttt
Old Feb 29, 2008 | 04:44 PM
GRAF-FITI's Avatar
* B A N N E D *
ask papa5murf...he knows all about CAMS
Old Mar 1, 2008 | 08:47 AM
EJ8 GSR-T's Avatar
Default Re: Skunk2 Turbo cam? (GRAF-FITI)
Old Mar 2, 2008 | 06:19 PM
papa5murf's Avatar
I don't think anyone has tried/installed these as of yet. I don't see much gain in them though. The NA cams do virtually nothing. So I figure the turbo cams will be comparable to the NA cams performance as a whole.
Even so, cams in general on the S will not be worth it. If you're turbo charged, you'll get plenty of power without the need of little extras such as this. It's not a B-series motor when you need to change everything to achieve high HP numbers.
Old Mar 2, 2008 | 06:44 PM
papa5murf's Avatar
Default Re: Skunk2 Turbo cam? (papa5murf)
Did some extra research.
Show's:
max power with the cams was 418
max power without the cams was 429
Here's a thread. http://www.s2ki.com/forums/ind...&st=0
Looks like complete utter failure with the cams.
Old Mar 2, 2008 | 11:04 PM
EJ8 GSR-T's Avatar
Yuck, thats not exactly confidence inspiring! I have a set of them in my coupe (gsr) motor and they work great, but i guess different motor is a different story. One other question..not specifically related. Will turbo cams work well on supercharged motors? I would imagine the intake would be the same but on the exhaust cam (say you were to custom design your own cam) would you change things up?
Old Mar 3, 2008 | 04:39 AM
papa5murf's Avatar
I wouldn't even mess with cams on the S2000 to be honest. Honda did their research & development to the fullest of their abilities before releasing this car. There's not much improvement to be made anywhere without going to drastic measures.
Old Mar 3, 2008 | 04:56 AM
HondaKyle's Avatar
Its the same with the skunk2 cams on the H22 with a turbo... weird
vtec4max
Jul 30, 2007 02:49 PM
londa hover
Nov 15, 2004 12:46 PM
usdmcivic94
12
Jul 12, 2004 03:04 PM
4ghatch
Feb 2, 2003 09:36 PM
Black Sheep
Jun 21, 2002 06:59 AM
