Loss of power after tune up wtf!!
yesterday i did a full tune up myself, i changed tranny oil honda mtf 3 qrts!, motor oil, spark plugs and wires ngk, dist. cap/rotor, fuel filter honda. today i was driving and did some pulls in 3rd and it feels alot weaker i feal a power loss definetly, it pulled almost twice as hard before the tune up. It seems to feel weak in v-tech, im confused in why this happened. My car is fully built gsr 11:6:1 comp. any help/input would be great. P.s can over filling the tranny couse this theres 3 qrts in! please help!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wunfstgsr »</TD></TR><TR><TD CLASS="quote">P.s can over filling the tranny couse this theres 3 qrts in! please help!!
That would be the most obvious place to look first. Drain nearly a quart out and then try your car out. If it's still off, check your ignition timing.
</TD></TR></TABLE>That would be the most obvious place to look first. Drain nearly a quart out and then try your car out. If it's still off, check your ignition timing.
vtech is a telephone
the "H" that you see on the bottom half of the valve cover isnt there to get tacked on after the last letter of vtec. It stands for "honda"
*welcome to the world of hondas*
The specified amount of gear oil for a gsr m/t is 2.2 qts if you put 3qts its too much but I doubt that's what's causing the loss of power. I would check the fuel pressure if you have a fuel pressure guage and also the ignition timing.
No! i should of, i actually forgot i always do stupid me i'll try that and see !
