b16 sedan bogging need help
Old Feb 27, 2008 | 10:36 AM
B16acivicsedan91's Avatar
Default b16 sedan bogging need help
I have 91 sedan b16 obdo with a bit of an issue. over the past 2 weeks this little hesitation problem started up. it got worse little by little and turned into a massive bogging problem. it happens at low rpms but not at idle. get it into vtec and some times its there sometimes its not. I changed plugs, wires, cap, rotor, fuel filter, verified have good fuel pressure, changed all vac hoses and pvc valve, changed both o2 sensors and ver were on correct header bank. checked all ecu connections, i am really not sure where to go from here, any help would be appriciated guys. help a fellow ef driver out
Old Feb 27, 2008 | 01:51 PM
Default Re: b16 sedan bogging need help (B16acivicsedan91)
also there is no check engine light when it happens
Old Feb 27, 2008 | 07:56 PM
bump for at least a few suggestions
Old Feb 28, 2008 | 05:30 AM
alscrx's Avatar
Check you timing, dizzy, and TPS position.
Old Feb 28, 2008 | 06:23 AM
Default Re: b16 sedan bogging need help (alscrx)
The dizzy and timing are fine but i will check the tps thanks
Modified by B16acivicsedan91 at 7:43 AM 2/28/2008
Old Feb 28, 2008 | 09:39 AM
I am going out to buy the tps sensor. I was told any tps sensor from a 88-00 honda that is mpfi will work is this correct?
strictlyimport
Apr 12, 2006 04:51 PM
89turbosi
Jun 10, 2003 07:28 PM
DOHCRX
May 13, 2003 01:50 PM
Tripz
May 13, 2002 05:18 PM
ricodemus
May 10, 2002 10:40 PM
