How hard is it to convert automatic to stick shift???
Old Feb 27, 2008 | 10:06 AM
MUGEN_EG95's Avatar
Default How hard is it to convert automatic to stick shift???
I own a 95 honda civic ex coupe and i was wondering how difficult it will be to do the conversion? What will i need to get and how much will it cost without labor?
Old Feb 27, 2008 | 11:54 AM
thatonekid's Avatar
you will need the following
Search button
Old Feb 27, 2008 | 12:29 PM
tazeat's Avatar
How hard is it to read the FAQ to a noob???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">This is the FAQ section for '92-'00 Civics/Del Sols
Transmission:
General Info On Automatic Transmissions
'92-'00 D series Transmission Fluid Change
'96-'00 Auto to Manual Conversion
'96-'00 Automatic to Manual Conversion (No Pictures)
Parts List For '92-'95 Automatic to Manual Conversion
Auto to Manual Swap For Civics - Detailed Parts List and General How-To
D Series Transmission Tear Down (and how to inspect the input shaft bearing)
Changing Transmission Fluid (No Pictures)
Remove Transmission
Short Shifter Install
Short Shifter Install (No Pictures)
Parts List For Auto To Manual Conversion
Identifying B-Series Transmissions
Creating a Shifter Extension
Creating a Shifter Extension #2
Gear Ratios for '92-'95 CX, DX, LX, VX, EX, and Si; '90-'91 JDM Integra RSi, XSi; '90-'93 Integra GS, LS, RS; '94-'01 GS/LS; '98-'01 JDM ITR; '93-'01 GSR/JDM SiR; '90-'91 CRX SiR/Civic; DOHC Del Sol VTEC/'99-'00 Si; '95-'97 ITR/JDM ITR; '92-'94 GSR/JDM Integra XSi; RSX/RSX-S.
Old Feb 27, 2008 | 12:57 PM
jasony0630's Avatar
76.26.106.124
easy as F*CK.
takes maybe a day....for me to do atleast.
Old Feb 27, 2008 | 01:02 PM
serio_ENDLESS's Avatar
takes me 2-3 hours to complete a auto to manual
Old Feb 27, 2008 | 01:04 PM
crazyguy's Avatar
Default Re: (serio_ENDLESS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serio_ENDLESS &raquo;</TD></TR><TR><TD CLASS="quote">takes me 2-3 hours to complete a auto to manual </TD></TR></TABLE>
and how much do u charge?
Old Feb 27, 2008 | 01:06 PM
saywhat's Avatar
Default Re: (thatonekid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatonekid &raquo;</TD></TR><TR><TD CLASS="quote">you will need the following
Search button
It is people like you that give the best argument to not search, post a expletiveing link, rather than causing all the dead ends when people do use the search function... There is nothing more frustrating than searching and finding dozens of threads that say "search n00b"...
Try reading these = https://honda-tech.com/zerothread/1900308
Old Feb 27, 2008 | 01:08 PM
with me supplying all the parts with labor and ecu about $1000
Old Jun 28, 2010 | 12:53 PM
brobz's Avatar
Default Re: How hard is it to convert automatic to stick shift???
Could u convert a 96 accord lx and how much would u charge???
Old Jun 28, 2010 | 01:28 PM
titi_vtec's Avatar
hey i did a swap already, u need tranny 300$, clutch , presure plate, flywheel, shifter(complete kit 200$), pedals 50$, clutch master cylinder and slave one 40$, need front mount 20$, upper one too i thinks for eg 30$, need starter 60$, i think that u need all of that
Old Jun 29, 2010 | 12:42 PM
brobz's Avatar
Is there any one im cal that can do it for me puttin in every thing and wat would be the price
Old Jul 19, 2010 | 10:48 AM
89CRXHFB16A's Avatar
Im new here can anyone point me in the right direction. I need to do an AUTO to MANUAL conversion from my 91 crx dx in to my 89 hf. Please help me out i need to get started asap.
Old Aug 4, 2015 | 10:49 PM
PSYCHOS_CB7's Avatar
How much would it be to do this swap on a 90 accord 2 door
Old Aug 5, 2015 | 02:57 AM
NotARaCist's Avatar
I never narc'd on nobody!
Failure #1: You're in the Civic section. Accords have their own section. Go there.
Failure #2: You didn't bother reading the FAQ sticky, in the wrong section that you're in.
Failure #3: You didn't bother reading the rules sticky, in the wrong section that you're in.
Failure #4: You bumped a 7 year old, dead thread.
Don't do any of those things. Stop it. There are no excuses. Now go to the correct subforum, and try not to **** things up over there like you did here.
vteckyle
11
Jul 25, 2007 06:23 PM
96JDM4life
Nov 2, 2006 08:23 AM
Ryan124
May 26, 2006 01:25 PM
mrxhe1neken
Aug 10, 2004 02:19 PM
VtecbOi
31
May 7, 2003 01:28 PM
