Some help if someone can.
97Ek hatch
b18c1
-Skunk 2 Intake Manifold
-Cam gears
-Full exhaust
p2T
When the swap was done i think it was swapped with a Si wiring harness.
I believe its a obd1 Motor with a obd2 harnes and ecu
Ive had it started a couple of times but its not starting now.....
Should i get a p72? What else? What major grounds needed to be checked, it has a new battery, checked fuses.
b18c1
-Cam gears
-Full exhaust
p2T
I can turn the to acc. and hear the pump pumping. Changed the Fuel filter "pretty dirty" so i cleaned the injectors "they were dirty too". I have checked the ground on the started and battery. What other major grounds are there?
yeah use obd2 to obd1 harness conversion and use p72 ecu. grounds wires are. one at battery terminal. one from tranny to chassis. one from valve cover to radiator support. and check all your fuses
you using the stock b16a2 si p2t ecu and wiring harness so the ecu must be reading the crank sensor which the b16a2 has and obd1 b18c1 don't have so that could be it. convert it to obd2 to obd1 w/94-95 gsr ecu.
