wastegate vaccum line..
Old Feb 26, 2008 | 09:35 PM
418whpturboD's Avatar
Default wastegate vaccum line..
how many inches away from the turbo on my i/c piping can i run my vaccum line for my waste gate.. i heard no more than 10.. but not sure.. lmk thsnks
Old Feb 26, 2008 | 09:39 PM
Schister66's Avatar
Man U FTW
I take it that you're running a boost-only source to your wastegate. If this is the case, you can run it anywhere between the compressor housing and the throttle body. There is however the matter of pressure drop the further you venture from the turbo (especially after the intercooler). I'd imagine that Tial will stumble upon this thread and give you an exact answer.
Old Feb 26, 2008 | 09:58 PM
Default Re: (Schister66)
does it matter if its a boost only pressure source?
Old Feb 27, 2008 | 05:58 AM
TiAL's Avatar
Default Re: (418whpturboD)
there is no real set length, but i would keep it as short as possible for optimal response (obviously) and remember to use a pressure only source, NOT a vacuum/pressure.
Old Feb 27, 2008 | 06:43 AM
ghostskinner's Avatar
Default Re: (TiAL)
what would be a pressure only source
Old Feb 27, 2008 | 06:45 AM
blackcherry's Avatar
would the brake booster line be a vac/pressure source? what effect will this have if you run it like so?
Old Feb 27, 2008 | 07:05 AM
Schister66's Avatar
Man U FTW
Default Re: (ghostskinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostskinner &raquo;</TD></TR><TR><TD CLASS="quote">what would be a pressure only source</TD></TR></TABLE>
Anything between the turbo and the throttle body would be a pressure-only source.
Old Feb 27, 2008 | 07:32 AM
TiAL's Avatar
Default Re: (blackcherry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcherry &raquo;</TD></TR><TR><TD CLASS="quote">would the brake booster line be a vac/pressure source? what effect will this have if you run it like so?</TD></TR></TABLE>
if the engine has strong enough vacuum it can suck the diapragm into the side port and damage it.
Old Feb 27, 2008 | 09:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
Anything between the turbo and the throttle body would be a pressure-only source. </TD></TR></TABLE>
i have no ports in this area for my wastegate. . . no nipple on the turbo and no ports on the ic piping or tb, are you supposed to tap it to the bov somehow?
Old Feb 27, 2008 | 10:00 AM
95jeremie's Avatar
in for details
was thinking about this the other day
Old Feb 27, 2008 | 10:23 AM
TiAL's Avatar
i have no ports in this area for my wastegate. . . no nipple on the turbo and no ports on the ic piping or tb, are you supposed to tap it to the bov somehow?</TD></TR></TABLE>
yep, best thing to do is tap the compressor housing near the discharge
Old Feb 27, 2008 | 11:41 AM
Turbo-charged's Avatar
Default Re: (TiAL)
not into the bov---the bov gets its reference from a vaccume source.
we always drill and tap the compressor housing
Old Feb 27, 2008 | 12:27 PM
Default Re: (Turbo-charged)
iput it about a foot from the turbo on the ic pipe about 6 inches before the intercooler.. so its no ewhere nmear the manifold to over heat the line
Old Feb 27, 2008 | 07:26 PM
ls19integra95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">
we always drill and tap the compressor housing</TD></TR></TABLE>
do you have any pics that you could post to give a good idea of where and how to do it?
SiRCiviC94
Aug 28, 2013 02:24 PM
T25 civic
Jul 7, 2010 05:02 AM
Flr Power
Nov 13, 2004 06:11 PM
phase12gsr
Oct 28, 2002 08:00 PM
