Will 98 civic sedan body kit fit on a 98 coupe?
Old Feb 26, 2008 | 08:24 PM
jordan2011's Avatar
Default Will 98 civic sedan body kit fit on a 98 coupe?
I found a body kit, and it was on a 1998 civic sedan 4 door, and i know the front bumper will fit, and im pretty sure that the rear will as well, but will the side skirts fit? please let me know, that would be great. the coupe, is the same year also. thanks!
Old Feb 26, 2008 | 08:25 PM
ke98248's Avatar
Default Re: Will 98 civic sedan body kit fit on a 98 coupe? (jordan2011)
I have an idea -- don't put on the body kit! Unless it's a high quality body kit that isn't prone to breakage/cracking, stay far away...
Old Feb 26, 2008 | 08:26 PM
x0!'s Avatar
x0!
sedan side skirts are longer.
Eran's Avatar
HT White Ops
To answer your question: Yes, it will fit. The sideskirts may be a tiny bit short.
I use the word 'fit' lightly, as the fit of a body kit is only as good as it's manufacturing standards. Most of the time, they're both pretty shitty.
Old Feb 26, 2008 | 08:28 PM
mattyfo0z's Avatar
Default Re: (Eran)
^ Yeah, it should fit, but that's depending on how high the quality is on the body kit.
Old Feb 26, 2008 | 08:46 PM
jordan2011's Avatar
Well, i have gotten different answers, anyone else?
Old Feb 26, 2008 | 08:50 PM
jasony0630's Avatar
76.26.106.124
dont do it!!!!
Old Feb 26, 2008 | 09:55 PM
Cza_EM1's Avatar
Default Re: (jasony0630)
Bodykits FTL.
Old Feb 26, 2008 | 11:36 PM
NOFX's Avatar
H-T White Ops
Front and rear are exactly the same. '96-'98 coupe, hatch and sedan front bumpers all are interchangeable. The '96-'00 coupe and sedan rear bumpers are all interchangeable (the '96-'98 bumper is different than the '99-'00 bumper, but they are still fully interchangeable).
The sideskirts are the only difference. I've heard coupe/hatch and sedan skirts are the same other than the coupe/hatch ones, if put on a sedan will show a gap when the rear door is open. This means sedan ones might need to be trimmed on the inside rear in order to clear the underbody of the coupe/hatch, but I'm not 100% sure.
Be warned that many body kits can and will shatter or crack easily. They might also warp or be warped when you get them. Some require a professional to fit them onto the car because not knowing how to could end up damaging the body kit. Often even with professional fitting, they will not fit correctly.
Old Feb 26, 2008 | 11:41 PM
sanegb16's Avatar
no body kits will make you lose 100hp
i saw it on need 4 speed
lol but on a serious note the sedan has a longer sideskirt than the coupes and hatches
Old Feb 26, 2008 | 11:57 PM
NOFX's Avatar
H-T White Ops
All 1996 to 2000 Civics (coupes, hatches and sedans) have the same exact wheelbase (103.1 inches). So I don't understand why any sideskirt would be longer or shorter.
Old Feb 27, 2008 | 10:14 AM
NOFX's Avatar
H-T White Ops
I asked a sedan owner to measure his sideskirts. They came to 75 inches. Then I just measured the coupe/hatch sideskirts here. They're the same length.
Old Feb 27, 2008 | 11:21 AM
jasony0630's Avatar
76.26.106.124
it makes sense what nofx stated.
if you look at the sedans, the doors are like half the size of one door found on a coupe.
Old May 28, 2025 | 01:15 AM
NonVtecbuilder5's Avatar
Yes coupe body kits are interchangeable onto sedans (ex: EX to LX) bumpers and side skirts. Both the coupes and sedans have a length of 175.1 inches or 175inches.
(look at as many reviews and do as much research as you can on different companies who sell body kits and what they are made of! I believe there is like 3 different types of material body kits are made of. You want to get the most plyable (bendable) body kit you can (polyurethane) I believe; to prevent easy cracks when before&after install
Old May 28, 2025 | 04:02 PM
spAdam's Avatar
Loved
Community Favorite
Thanks for the insight. This thread is almost old enough to die for its country.
Jesse1997n
Sep 6, 2012 08:20 AM
Richibahn
May 5, 2009 03:04 PM
jordan2011
Paint and Body
Feb 27, 2008 10:20 AM
H22dave
Mar 26, 2004 05:26 AM
