96 obd2a gsr throttle body on 92 DA
Old Feb 26, 2008 | 06:53 PM
VTEC_Du_Ma_Mai's Avatar
Default 96 obd2a gsr throttle body on 92 DA
i know you can reroute the vacuum line on the map sensor of the da or rewire the map sensor from the gsr tb, but im a lil iffy about the holes in the tb. the gsr tb has only one hole inside and the da tb has 2 holes. what do you do with the 2nd hole in the manifold.
also can the tps from the da tb go onto the gsr tb. im selling an aftermarket tb that is exactly like a 96 gsr but without any sensors and some guy with a da wants it, if that helps. so basically, what can he do to make this work. thanks in advance.
Old Feb 26, 2008 | 08:43 PM
Default Re: 96 obd2a gsr throttle body on 92 DA (VTEC_Du_Ma_Mai)
any info will help
Old Feb 27, 2008 | 11:52 AM
95 integra's Avatar
The 92 has the FITV and the 96+ does not....its a worthless valve anyway, so the extra hole does not matter. The TPS will cross over as well.
Old Feb 27, 2008 | 05:09 PM
Default Re: 96 obd2a gsr throttle body on 92 DA (95 integra)
ok so all he has to do is:
1. swap the tps
2. reroute the map sensor vacuum line
3. bypass the fitv by connecting the 2 coolant lines together
is this correct? please verify, thank you.
Old Feb 27, 2008 | 05:29 PM
Dogginator's Avatar
Daisy... Daisy...
I would think that you would simply cap the vacuum line for the original MAP sensor. The MAP on the TB needs no vacuum line.
Also, why would you swap the TPS?
Old Feb 27, 2008 | 05:44 PM
Default Re: 96 obd2a gsr throttle body on 92 DA (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I would think that you would simply cap the vacuum line for the original MAP sensor. The MAP on the TB needs no vacuum line.
Also, why would you swap the TPS?</TD></TR></TABLE>
im not sure what you're asking but, im selling a gsr style tb with no sensors whatsoever to a guy with a DA. so he would need to swap his tps from his original tb to the one i have. as for the MAP sensor vacuum line, his map sensor is located on the firewall and my tb has no nipple for a vacuum line so im asking, would he need to reroute the vacuum line from his map sensor to his own manifold or something to make it work? i hope i have cleared it up and thanks for the response.
Old Feb 27, 2008 | 06:09 PM
95 integra's Avatar
Yes that is what you would need to do. The TPSs on the 90-9x (early model integras) are just screwed in and not "riveted" in like the 94+s)....not sure which year they stopped that (91 or 93). Then he can run a little plate w/ nipple where the stock MAP was for the vacuum source or one off the IM....either one.
Old Feb 27, 2008 | 06:18 PM
arite thanks a lot. thats exactly what i needed to know.
chris3385
Jan 3, 2009 04:49 AM
VTEC_Du_Ma_Mai
Feb 27, 2008 05:10 PM
Topdawgg
Jun 25, 2007 10:02 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
