How do i remove the pass airbag in my 96 civic
Old Feb 26, 2008 | 02:35 PM
one8toh8's Avatar
Default How do i remove the pass airbag in my 96 civic
like the topic says, i can not figure it out, i spent 2.5 hrs trying to today and no dice. I searched on here because i know i has been discussed before but i must not be looking for the right thing. I am in need of getting this out the airbag has deployed and it looks like crap. Is there any one that can hit me with a link or any info on where i can get info to get this damn thing out. Thank you in advance
Old Feb 26, 2008 | 03:06 PM
one8toh8's Avatar
Default Re: How do i remove the pass airbag in my 96 civic (one8toh8)
anybody
Old Feb 26, 2008 | 03:44 PM
jdmturbo1127's Avatar
Disconnect the wires and remove the screws. The tricky thing is that there are tabs on the airbag assembly that holds it on the dashboard. Being that the airbag is already deployed, grab a flat head screwdriver and pry that &*tch out
Old Feb 26, 2008 | 04:58 PM
v8 integra's Avatar
i replaced my air bags for my 96 ex last week...2 tiny bolts in the front..1 tiny bolt in the back.. 10mm....from underneath after u remove the 3 bolts..try to push the 3 bolt studs out of the holeand then start to pry from the top..and yeh..like jdmturbo1127 said..theirs tabs u have to pry open! it took me like 10 mins cuz i havent gone to the gym in like a month..lol..and also make sure when ur pryingg it with a flat head..try not to mess up the dash! good luck!!
Modified by v8 integra at 6:38 PM 2/26/2008
Old Feb 26, 2008 | 05:29 PM
one8toh8's Avatar
Default Re: (v8 integra)
yeah that is what im woried about, i dont want to fudge up my dash, the thing that im having issues with is finding the bolts. there is this dry foam stuff under the airbag so its alittle hard to see any bolts, i will try to check again on thursday, i have to work all day tomarrow, Thank you for the help.
Old Feb 26, 2008 | 05:41 PM
v8 integra's Avatar
the bolts are EASY to find...just make sure u take ur glove box off the hinges..or take it off completely...theres 2 10mm bolts right infront and u jus gotta get a lil lower to c the 3rd 10mm bolt..ive never done airbags till 2 weeks ago and i didnt fudge up my dash..lol..n i dont think my car had any dry foam..or i dont know at ur tlaking about..lol..good luck again!!
Old Feb 26, 2008 | 06:18 PM
spotscivic's Avatar
take your glove box out and its easy as fishing!
one8toh8's Avatar
im going to try on thursday and if i cant get it ill take some pics of the foam crap that im talking about, Thank you for the help
Old Feb 26, 2008 | 06:20 PM
one8toh8's Avatar
thats prob my issue i did not no i had to take the glove box completely out, i was just unhooking it so id just dropped down ill try that. Thanks again
Old Feb 26, 2008 | 06:23 PM
one8toh8's Avatar
i think when i finally get it out ill do a little write up because i could not find anything on it. im going to be putting a block off tray because airbags are so damn expensive.
Old Feb 27, 2008 | 07:01 PM
v8 integra's Avatar
Default Re: (one8toh8)
i let my glove box hang on the hinges..but i squeez it and take it off the stoppers..andd theres a guy on ebay who sells driver side and passenger side airbags with module for 190 shipped...
Old Feb 28, 2008 | 03:12 PM
one8toh8's Avatar
everyone thank you for the info, i think i figured it out, im going to wait to remove it until i get a block off plate.
Civic Racer X 7
Jan 20, 2011 02:19 PM
Honda_Modifier
Jun 3, 2006 01:19 PM
maxt
Aug 12, 2004 07:41 PM
kn1ghtrydr
Jan 11, 2004 12:57 PM
missinghubcabs
Jun 12, 2003 11:04 AM
