valve cover...?
Old Feb 26, 2008 | 02:27 PM
92egSnatch's Avatar
Default valve cover...?
ok so i recently discovered that the center bolt on my valve cover is striped not the actual bolt but the hole it screws into could this cause any problems and what should i do to fix it?
Old Feb 26, 2008 | 03:04 PM
92egSnatch's Avatar
Default Re: valve cover...? (01D17a1)
anyone???
Old Feb 26, 2008 | 03:06 PM
Tyler Con's Avatar
tap and die set you can rent it from autozone.
Old Feb 26, 2008 | 03:09 PM
92egSnatch's Avatar
Default Re: valve cover...? (Tyler Con)
wouldnt that make the hole bigger where would i get a new blot that has the same ring around the middle
Old Feb 26, 2008 | 03:10 PM
Eran's Avatar
HT White Ops
Put in a helicoil.
Old Feb 26, 2008 | 03:14 PM
92egSnatch's Avatar
Default Re: (Eran)
could i get one at autozone too
Old Feb 26, 2008 | 03:17 PM
Eran's Avatar
HT White Ops
Default Re: (01D17a1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01D17a1 &raquo;</TD></TR><TR><TD CLASS="quote">could i get one at autozone too</TD></TR></TABLE>
Yep. Just bring in your bolt and find one that'll thread.
Old Feb 26, 2008 | 05:14 PM
ddd4114's Avatar
Default Re: (Eran)
I'm pretty sure you'll need an M6x1.0 thread repair kit (Helicoil make one). Just to make sure, measure the major diameter of the bolt.
Old Feb 27, 2008 | 12:43 PM
92egSnatch's Avatar
Default Re: (ddd4114)
can anyone tell me where i can get this kit i looked online and they have it at ace hardware for $40!?
and theres not even an ace hardware store in austin
Old Feb 27, 2008 | 02:13 PM
ddd4114's Avatar
I used a Permacoil kit from Pepboys, and it worked fine. I think I paid $30 for it. However, it did not include the required drill bit, which I believe is 1/4".
Old Feb 27, 2008 | 02:34 PM
dragonfly2k3's Avatar
watch out, do not tighten that bolt tight, just snug. I helicoiled mine, a few months later the aluminum around it cracked off and ended up bending a valve
Old Feb 27, 2008 | 02:38 PM
ddd4114's Avatar
Default Re: (dragonfly2k3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonfly2k3 &raquo;</TD></TR><TR><TD CLASS="quote">watch out, do not tighten that bolt tight, just snug. I helicoiled mine, a few months later the aluminum around it cracked off and ended up bending a valve</TD></TR></TABLE>
Wow! What did you use for the torque setting on your wrench?
Old Feb 27, 2008 | 02:47 PM
1992Si's Avatar
Any auto parts store will have a insert kit.
Is it leaking oil at the valve cover seal? if no, leave it alone and put a rubber plug in where the bolt goes into the cover.
If you need to drill and install an insert, make sure you don't get any metal chips in the oil pan.
The oil filter should catch small chips, but I don't think any one here would want to risk it.
Do not torque these old bolts. Just put them slightly more then hand tight. The rubber gasket seals, it's not about how tight the old bolt is.
At over 100psi of oil pressure in the race engine we never had an oil leak. I would just use the 1/4" ratchet like a screw driver, not like a ratchet.
Old Feb 27, 2008 | 07:55 PM
92egSnatch's Avatar
Default Re: (1992Si)
eh well its not leaking oil its seems fine, so if its not broken dont fix it right?
ill just leave it the motors getting swaped anyway
Old Feb 27, 2008 | 08:01 PM
I used a nut driver and did them snug. I think it had to do with the fact that to put the heli-coil in it makes thin aluminum even thinner.
jwicecold
Oct 21, 2008 04:51 AM
Cashieboi
Oct 16, 2006 09:28 PM
beat_nut
36
Apr 9, 2005 03:49 PM
D16SohcVtec
14
Oct 15, 2004 08:42 AM
freeeked
Aug 16, 2003 04:19 PM
