where dose this wire plug in to. eg fog lights?????????????????
Old Feb 26, 2008 | 01:10 PM
EGKREW's Avatar
Default where dose this wire plug in to. eg fog lights?????????????????
these are ebay fog light for a eg. where dose this wire plug in to?
Old Feb 26, 2008 | 01:17 PM
saywhat's Avatar
Default Re: where dose this wire plug in to. eg fog lights????????????????? (EGKREW)
I am going to say your parking light accessory plug on your under dash fusebox. But I am not 100%
Old Feb 26, 2008 | 01:54 PM
EGKREW's Avatar
Default Re: where dose this wire plug in to. eg fog lights????????????????? (saywhat)
Old Feb 26, 2008 | 04:39 PM
EGKREW's Avatar
HELP
Old Feb 26, 2008 | 05:44 PM
VTECcivicDOWORK's Avatar
if those fogs are the same as mine, the black wire on the right is your ground, middle [yellow] is either your positive or negative that goes to into switch and the other wire on the left [next to the yellow one] would be your other positive or negative wire that goes into your switch. but since the yellow wire is 2 wires its kinda different? id say try and ground out the wire on the right, and then plug the other 2 wires into your switch. see what happens. if you blow the fuse then just go pick up a couple more. i got 6 at radio shack for like, 2 bucks. if you mess around with it, youll be able to figure it out =]
Old Feb 26, 2008 | 05:46 PM
BlueIntegraBoy's Avatar
Is it a spader connector? Plugs into the accessory slots on your fuse box.
I would plug it into the 2nd one from the right (No. 19 Headlight) fuse. So your fog lights come on with your headlights.
However, if you want your fogs to come on without your headlights, plug it into any of the other four slots.
Old Feb 26, 2008 | 05:47 PM
oh yea, another thing that you could do is if you know about wiring at least a little bit you could strip those wires and rewire it all. its not that hard. if you dont know how, PM me and ill explain it.
Old Feb 27, 2008 | 06:05 PM
EGKREW's Avatar
Default Re: (MarcusMassacre)
it didnt work
Old Feb 27, 2008 | 06:43 PM
Default Re: (EGKREW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW &raquo;</TD></TR><TR><TD CLASS="quote">it didnt work</TD></TR></TABLE>
Did you try my method?
Old Feb 27, 2008 | 07:40 PM
EGKREW's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Did you try my method?</TD></TR></TABLE>
ya but it didnt work
Old Feb 27, 2008 | 08:20 PM
laocivic's Avatar
i had ebay fogs n its the way integraboy sed. u must have simething else wrong
Old Feb 27, 2008 | 09:25 PM
speedooo's Avatar
Default Re: (laocivic)
Make sure you have nice clean grounds, the fogs do in fact plug in to that spot in the fusebox
Old Feb 28, 2008 | 04:14 AM
z6hatchboy's Avatar
My depo's are the same wire coloring as yours i believe, and i just went outside to look at it for you and the two yellows that come to a spade connector are my power, i just crimped a male spade onto a wire and ran a wire back inside to my fuse box i think to the radio fuse.
williamcollins
Jul 8, 2017 01:24 PM
jdmsir4dr
Apr 25, 2013 08:33 PM
crx_si-r
Feb 8, 2010 04:55 PM
B16Vtec
Aug 20, 2001 05:24 AM
