Question about divide turbo housing on non-divided manifold
Hello guys,
I'm from Holland and I'm in the process of switching from a 14b to a big 16G. Is it possible to use a turbo with a divided housing on a non divided manifold? Will there be any consequences?
Thanks guys
Thanks guys
I thought it wouldn't harm anything and I found an article on the internet, were was said: "While it does not cause any problems or harm to run a divided inlet turbine housing on a manifold that is an "open" design, none of the benefits of the twin inlet will be seen
It changes your effective a/r ratio, reducing spool.
You're talking about the evo 16g, right? I didn't think you could bolt a twinscroll evo turbo up to a single scroll 14b/single scroll 16g manifold, the twinscroll ports aren't even close to the same dimensions as the single entry. ?
Am I misremembering this?
wade
Sep 18, 2011 08:11 PM
dimensions, divided, divied, h22, housing, manfiold, manifold, manifolds, nondivided, put, run, scroll, single, turbo, twinscrollmanifoldd16
