ek with h22a electrical problems
ok last night i was looking at the ecu to see how i could hook up my a/f gauge,but i didnt unplug anything. this morning i go to start it up and it makes a horrible noise, and will not give me any power. giving me codes for the map sensor and electrical load detector. well i go back and look at the ecu notice a loose connection. well that fixed the map sensor, car runs more normally and sounds normal. but the Electrical load detector code is still showing up. then i notice that my water temp, speedometer, battery voltage gauges are all not working and my car idles at 1000 even, normally at 500+-50. and in 4th or 5th gear if i give a good amount of gas it seems to hesitate. any info is greatly appreciated.
The ELD should be under the fuse box in the engine bay, a lot of people just take it out and clean it with electrical cleaner or something and that solves it.
Pullig
Apr 27, 2007 05:29 PM
AnclyT
Jul 22, 2005 05:41 PM
AnclyT
Jul 19, 2005 04:49 PM
