broken motor mounts.... again...
Old Feb 25, 2008 | 11:44 PM
wreckmaster678's Avatar
Default broken motor mounts.... again...
90 cb7 with a f22b swap. I seem so roast any stock motor mount I put in there. Both the front (by the radiator) and the left (by the timing cover) die within a few months. Anyone have this problem? Wondering if there are aftermarket ones available, short of solid mounts. This is getting expensive when I could be using that money to complete my boost fund...
Old Feb 26, 2008 | 02:56 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: broken motor mounts.... again... (wreckmaster678)
have you thought about using some urethane from McMaster-Carr in a hardness of say 63A so it's not real stiff to add a lot of vibration but something stiffer than the OEM mount itself?
Old Feb 26, 2008 | 03:44 AM
YeuEmMaiMai's Avatar
is it turbo? if you are pushing an excessive amt of power on the motor the mounts are not gonna last
Old Feb 26, 2008 | 08:52 AM
H22_aCCoRd_07's Avatar
Default Re: broken motor mounts.... again... (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">is it turbo? if you are pushing an excessive amt of power on the motor the mounts are not gonna last</TD></TR></TABLE>
He said he had a boost fund, which means he is saving up to go turbo eventually
Old Feb 26, 2008 | 08:56 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: broken motor mounts.... again... (H22_aCCoRd_07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22_aCCoRd_07 &raquo;</TD></TR><TR><TD CLASS="quote">
He said he had a boost fund, which means he is saving up to go turbo eventually </TD></TR></TABLE>
Oh I'm glad you can read the OP"s mind.
It doesn't say he isn't currently boosted, you CAN upgrade parts you know........
Something is wrong if a stock motor eats through OEM mounts quickly.
Old Feb 27, 2008 | 06:14 AM
Default Re: broken motor mounts.... again... (TheMuffinMan)
The engine is bone stock for now. I have a turbo, but it is not on the car yet. I still need a ram manifold and pipes run. I do play pretty hard with it. Well, as much as I can with a stock engine..... I have poked and prodded with the engine and everything seems to line up ok, nothing seems to be binding. Sooo........???
Old Feb 27, 2008 | 08:43 AM
are you constantly WOT?
how does the trans shift?
is the REAR MOUNT vaccum connected and working?
Old Feb 28, 2008 | 02:36 AM
Trans shifts fine, not all the time wot, and I can't remember about the vaccum line on the rear mount. If I'm correct (??) I'm not sure if the manual trans has a vaccum line going to it or not, but the rear mount is fine. Haven't had to replace it. I'm just left scratching my head and trying to figure out WTF is going on here.
Old Feb 28, 2008 | 03:22 AM
H-T Order of Merit
well, you never said if it was a manual or auto tranny either so...
not sure about the 90-93 Accord different between the rear mount but on the 94-97 the rear mount of a manual didn't have the vacuum setup while the rear mount of an auto did.
ilovejdmhoes23
Jan 18, 2007 04:32 PM
zx2gotboost
Nov 28, 2005 10:33 PM
hotdoggies
10
Mar 7, 2005 07:47 AM
ek9800
Sep 6, 2004 08:48 PM
6GACCORDH22
Sep 11, 2002 06:01 AM
