How do i adjust ZEX 59300 cam
Old Feb 25, 2008 | 04:41 PM
ERKK's Avatar
Default How do i adjust ZEX 59300 cam
I dont know how to adujust my valves to my cam i dont know how fare it should be set i bought the car off this guy and it ran awesome and my buddy hes a machnic and hes like adjust them now its worse then what it was when we started dose anyone know how fare arapt
Old Feb 25, 2008 | 04:56 PM
SIred91's Avatar
Rainman
Default Re: How do i adjust ZEX 59300 cam (ERKK)
Why did you mess with what wasn't broken?
Old Feb 25, 2008 | 05:00 PM
Johnny-Red's Avatar
Your buddy ain't to great of a mechanic is he?
Old Feb 25, 2008 | 05:09 PM
ERKK's Avatar
see im new to the whole car deal like i know a little.. so im a noob i guess u could call me lol but i bought the car its fully build sohc D16a6 and hes all into honda so i thought he knew what he was doing hes like it sounds like u need a valve adjustment and thats where my trouble strated dose anyone know how fare im to adjust them
Old Feb 25, 2008 | 05:12 PM
1kleenef's Avatar
Default Re: (ERKK)
roughly .007 for most hondas idk if the cam changes anything or not but thats wat stock specs are o and please tell me the guy was at least using feeler gauges?
Old Feb 25, 2008 | 05:16 PM
ERKK's Avatar
yea we did he said 40 thousands or omething ?
Old Feb 25, 2008 | 06:31 PM
1kleenef's Avatar
Default Re: (ERKK)
yea if he said 40 thousandths for a valve adjustment he needs to be no where near a car
Old Feb 26, 2008 | 08:16 AM
ERKK's Avatar
bump
Old Feb 26, 2008 | 12:12 PM
c0d0r's Avatar
Go pick up a hayne's/helms manual for YOUR car. Should tell you step by step on how to do it.
I put a set of 95' GSR cams in my b16a, first cam swap I did. I used a haynes manual for a dc2 integra and adjusted the intake valves to around 6 thousandths of an inch and the exhaust to around 7 thousandths of an inch. Car runs good and no tappy..other than the lmas...
BEFORE YOU DO ANYTHING! Talk to the people at the ZEX company and ask them for the valve lash clearance using that cam on your engine. I would use stock specs...but you never know
Good luck
Old Feb 27, 2008 | 07:06 AM
ERKK's Avatar
BUMP some help me out its my Daily Driver!!
Old Feb 27, 2008 | 07:30 AM
IT GUY's Avatar
Default Re: (ERKK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERKK &raquo;</TD></TR><TR><TD CLASS="quote">BUMP some help me out its my Daily Driver!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0d0r &raquo;</TD></TR><TR><TD CLASS="quote">Go pick up a hayne's/helms manual for YOUR car. Should tell you step by step on how to do it.
Good luck </TD></TR></TABLE>
what else do you need OP? adjust your valves correctly and don't let your "friend" near your car again.
Old Feb 27, 2008 | 11:42 AM
ERKK's Avatar
well i did a compersion test and there all good but 1 BOO any one know of some good vaslves?
Old Feb 27, 2008 | 01:18 PM
1kleenef's Avatar
Default Re: (ERKK)
there are nothing wrong with the valves in your car y dont u just them right apparently they were working before this @ss clown of a mechanic screw the up so set them to spec (what ever zex says to set them to) and be done with it and stop asking question after question about wat u r supposed to do. Valves are a lot harder to replace than to just adjust the ones that are in there now.
Old Feb 27, 2008 | 05:28 PM
c0d0r's Avatar
I seriously thought you were here for some help..you arent even making sense anymore. Seriously...you cant be joking.
Old Feb 27, 2008 | 06:34 PM
gnar kill's Avatar
Default Re: (c0d0r)
I have a 59300 cam too the specs are on the box it came in or you can look it up on line. Just google it I don't remember what they where but they were slightly different than the factory cam specs
Old Feb 28, 2008 | 06:23 AM
ERKK's Avatar
i called zex its .007 intake and .009 Exhaust
Old Feb 29, 2008 | 09:03 PM
ERKK's Avatar
well i adjusted them to the specs.. and now its taping i took it to a local shop they told me they need re adjusted but they dont have to tools to do it and its snowing like crazy here so i cant go out side and play with it but im hopeing to take it to blair honda tomarrow i hope it gets fixed cuz shes my DD If anyone has any ideas of what the taping noise could be i thought bent valves but i duno
Old Mar 1, 2008 | 06:39 AM
1kleenef's Avatar
Default Re: (ERKK)
how can they not have the tools to do it they consist of a screwdriver, a wrench and a rachet???
Old Mar 1, 2008 | 07:00 AM
89s1's Avatar
Default Re: (1kleenef)
and the feeler guages. cant forget those, they're SUPER RARE
Old Mar 1, 2008 | 07:19 AM
ludesrv's Avatar
What mechanic / shop doesn't know or have the tools to do a valve adjustment? You need a new mechanics and a new shop first.
Adjust them to stock specs. SOHC are a bit trickier to get right and make sure you follow a honda manual on how the feeler gauge should slide in and out and what not.
Oh, and SOHC from honda always tick a little I find. If one of your cylinders is low don't assume its a valve, do a leak down test and actually find out whats wrong cause it could be a HG or rings too.
Old Mar 1, 2008 | 07:21 PM
ERKK's Avatar
Thanks for all the help if anyone has any more idea i wouldnt mind listning lol
Old May 15, 2008 | 10:31 AM
HYPROPULSION_R's Avatar
Default Re: (ERKK)
Did you make sure the engine was cold before you did the adjustment? You can't do a proper adjustment unless the engine is completely cold.
onereving7
Jan 14, 2008 06:50 PM
sibluecrx
Feb 1, 2007 08:50 PM
ITSTOCK
Sep 24, 2003 07:19 PM
Aron Parsons
Feb 4, 2002 06:38 PM
DaNish
Jan 18, 2002 09:55 PM
