bolt remover?
ok guys, i snapped a socket wrench, bent a thick socket wrench, both with the help of a 3 1/2 foot breaker bar. There are some seriously tight bolts on my subframe. How on earth do i get them off? What is a good bolt spray? something strong. Not crappy wd40, i know there are way stronger ones that you can let sit for 10 min and they they come off easy as pie.
suggestions?
suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drbenne »</TD></TR><TR><TD CLASS="quote">I used this sutff called PB penetrating catalyst on my flywheel bolts the other day. I thought it worked pretty well. </TD></TR></TABLE>
Thats good stuff, also make sure you use 1/2" drive tools, and impact sockets are much harder to break too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">i know there are way stronger ones that you can let sit for 10 min and they they come off easy as pie.
suggestions?</TD></TR></TABLE>
I soaked the bolts then let it sit for about 15 minutes, then sprayed it again and let it sit for another 15 and they came off pretty easy.
Yeah, I definitely vote for "PB Blaster"; it's in a white and yellow spray can and should be at most automotive stores. Don't settle for anything less!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">impact gun.</TD></TR></TABLE>
x2.
x2.
_Cyclone_
10
May 16, 2005 01:15 PM
