Fuel sending unit?
hey guys ive been searchin but no luck on the my subject. i need to replace my fuel sending unit asap. it acts up. ill completly fill her up and my guage will say its only 3/4 full. anyone have a thread on replacing it and the parts for it
you just need the sending unit and gasket. The gasket should be included with the sending unit. basically you remove your backseat to reveal a metal cover with three screws and a plug. remove the metal cover. use a hammer and screwdriver to remove the part with two tabs underneath. Then you should see a rubber gasket that creates a vapor seal and the sending unit.
it's a $40 part that should take 20 minutes in install.
TripleLude
20
Feb 20, 2014 03:59 AM
