high idle b20 vtec
Old Feb 23, 2008 | 02:24 AM
kcdog's Avatar
Default high idle b20 vtec
quick back ground i parked my car on a street that always floods when it rain which i didnt know. i went to the car a couple days later the inside was flooded(ecu under water), i went to start it and apperently there was still water in the intake got hydro lock and blew a rod out of the motor. so i salved the head and bought a block i did the swap my self, i plugged up the hole gor vtec on the heqad put a samwich kit on and ran a line for vtec, ok finnaly my question, it idles at around 2500 all the time. even if im gear it will pull up to 2500 then stay. i replaced the tps,cold start,and map. the only code is an auto tranny light(but the ecu is for a manual and never thre that code before) im using the stock b18c ecu that was sumerged in water. im saving money for a new custom ecu im lost on what to do. could it be the ecu?or an adjustment i dont know about(i hope lot cheaper). thanks
Old Feb 23, 2008 | 04:47 AM
cachase1's Avatar
Default Re: high idle b20 vtec (kcdog)
Have you checked the tension on the throttle cable? I know this seems pretty basic, but I sometimes overlook the most simple things and thought I would put it out there.
Old Feb 23, 2008 | 08:39 AM
Abandoned Ship's Avatar
New medicines
check your vacuum lines.
Old Feb 23, 2008 | 01:07 PM
kcdog's Avatar
i know the thottle cable has some slack on it and the butterfly is closed at idle
Old Feb 23, 2008 | 01:10 PM
kcdog's Avatar
i know the vaccum lines are good condition they didnt come off for the swap so the should still be in the correct places
joiv21
Jun 17, 2013 05:38 AM
hollywood97civic
Nov 5, 2012 12:46 PM
slo97coupe
Feb 11, 2007 03:00 PM
dblock91
Nov 16, 2006 08:05 PM
EJCivJdM93
Jan 28, 2005 09:58 PM
